Any steel wheel gurus?
I have 4 14" steelies here. The only stamping I can find on 3 them says "ELECTROFU"
The 4th one reads Kelsey Hayes Canada JK on the inner portion. stamped to the left of the valve stem reads K2 with a #9 underneath. then 2 .
Right side of the valve stem reads 14 and 55.
Any ideas on either?
The only thing I could find was in a corvette restoration book.
The wheel example in the book read: K12 4 and other side of stem read: 13 AZ
K=Kelsey-hayes
1=Chevrolet division ?
2=1972
4=April
13=April 13
AZ= 15" x 8 " Corvette application.
Judging by this example, my wheel is,
K= K.H.
2= ??? motor division
9= 1969
2= Feb.
14=feb 14
55= Wheel code for ???
K=Kelsey-hayes
2=1972
4=April
13=April 13
K= K.H.
9= 1969
2= Feb.
14=feb 14
K=Kelsey-hayes
2=1972
4=April
13=April 13
K= K.H.
9= 1969
2= Feb.
14=feb 14
K=Kelsey-hayes
2=1972
4=April
13=April 13
K= K.H.
9= 1969
2= Feb.
14=feb 14
2 should signify Pontiac. Henry
I discovered the "electrofu" wheels were 1965-1967 mopar wheels from big block cars, And were made by Motor Wheel.
Motor Wheel Electrofuse.
I found the pic on Classicchambered.com. They have a ton of wheels for sale on there.
Henry, I believe 4 is Olds, but I am unable to verify it. Kelsey Hayes codes for Chevy are out there, but I can't find a source that decodes them "all".
"Electrofuse" was the term MotorWheel coined for their manufacturing process. It is not exclusive to those Mopar wheels. I have MotorWheel Olds steel wheels with "ELECTROFUSE" stamped inside.
Last edited by wmachine; Nov 20, 2013 at 07:55 AM. Reason: Corrected reference to Kelsey Hayes wheels.
My guess stems from the GM ID system where first number of a chevrolet vin is 1, pontiac is 2, Olds is 3 and buick is 4.??????????????
Henry
[QUOTE=66400;617457]
That certainly makes sense. I'm sure there is more info available about those codes, I just haven't found it.
Henry, I believe 4 is Olds, but I am unable to verify it. MotorWheel codes for Chevy are out there, but I can't find a source that decodes them "all".]
Henry
Henry
Thanks for the insight, Kurt.
I have also heard that the second number in the sequence isn't a division code at all, but a plant code.
1 could be Romulus, MI instead of Chevrolet division for example.
I don't know for certain, just trying to learn a thing or 2.
I'd like to find more of what I've attached here.
The spare in my very late build '68 442 is:
left (of hole), K481 5
right, 13 TW
So, judging by the paperwork,
k=kelsey
4=plant code
8= 1968
1= January
5=? I have no clue what this renegade number is. Possibly 14x5?
13=Jan 13th
TW= Wheel code
So......that kind of defeats the logic of standard division numbers with your olds wheel being a 4. Most likely plant code.
Interesting...
All 5 of the rims on my 68 442 read:
K1
7. 11. Hole. 27 HF
With 4 piston calipers...corvette rims?
Car assembled in Oshawa first week in Jan 1968
K1
7. 11. Hole. 27 HF
Hopefully your wheels aren't lopsided because of being made 1st thing Monday morning haha.So, Kelsey plant #4 calls 442 wheels TW and at plant #1 they call them HF. I find that to be pretty random.
Now the new question is.....Why does 1 68 442 have HF codes and another have TW? I'm beginning to think that this "correct letter code" thing is a sham, and doesn't matter too much. Hard road to enlightenment here.
And if kurt's wheel was truly made on Jan, 13th like I'm theorizing .....That day was a saturday, and mucks things up even more.
So, in summary, I'm about as clear as mud on this matter.
K= Kelsey Hayes
1= plant code(Romulus MI) that apparently made mostly Chev rims...
7=date,(1967)
1=month(Jan)
1= Day of month(1)
...these wheels were made New Years Day
27 HF...shift???
More research......
7=date,(1967)
1=month(Jan)
1= Day of month(1)
?27 HF...shift???
More research......
no, what J had is right. 11/27/67 and HF is the application code. HF is a 68 model year wheel code and your date backs this up. Since your car/body was built the first week of Jan 68, the rims predating that by 5 weeks makes perfect sense. btw, dual piston disc brakes where an option on your 68 442
So your wheels would be 11-27-1967 That's pretty
1. The plant code won't tell us much, I've also found "1=Romulus, MI, 2=Windsor, ON, 3=Philadelphia, PA" and the plants could have made wheel for many makes.
2. The "application" code may be a code for the spec of the wheel (size, baclspace, etc)
I'm contacting Jim Larson as he has done a lot of research of wheels.
Kurt, does your car have them?
Also, really
to know the rims from the car are prob original...but as J says, what's up with the different application codes?
I was thinking that the application code could be related to the car coming with the dual piston brakes, specifically in 1968.
Also, really
Also, really
to know the rims from the car are prob original...but as J says, what's up with the different application codes?As far as wheel codes go:
Example: K 1____7(valve)26 _____LZ
_________9
K1 w/9 below is Kelsey Hayes, plant 1 as was said above, year 1969
7=July
26=July 26th
LZ=specific wheel code this one being for the 70-72 SSI
Motor Wheel Corp. did the same thing but had an M where the K is above.
k=kelsey
4=plant code
8= 1968
1= January
13=Jan 13th
TW= Wheel code
k=kelsey
4=plant code
8= 1968
1= January
13=Jan 13th
TW= Wheel code
K481 _____5(valve)13 _______TW
If so, the are dated May 13, 1968. The 1 next to the 8 looks to be just like the 5 in my Vette wheels above.
The code indicated the particular application of the rim. For example a single "R" stamp by the valve stem would be a early 68, a 67, orr earlier olds 442. A single "6" to the right of a valve stem would be a early 66 chevelle SS or an early GTO. Kelsey Hayes used three different stampings for 66 chevelles, depending on when the rims were manufactured.
For chevys there were at least three company manufacturing rims, Kelsey Hayes (4 plants), Motor Wheel (later bought in the 70's by KH), Norris Technologies (out in CA) . I have seen 442 rims coded R made by KH and Motor Wheel; but would think NT also made them.
Depending upon the manufacture there were some different style of stamping on the tire side of the rim and on the center section. And in the case of Motor Wheel the design of the outer rim and center section was a little different than say KH for the "R" coded rims.
I think the original poster is reading the code incorrectly. It should be a two letter code. Maybe he will repost with a correction or photo.
Kelsey Hayes, Plant 2, 1969, Feb 14, 55 (incorrectly read).
For Sammys rims Kelsey Hayes, Plant 1 Romulus, 1967, November 27, code HF (standard steel disc brake rim with 1.00 offset).
For Orange 442, KH, Plant 4, 1968, May 13, code TW.
Chevy started using the same style rim for disc and drum brakes sometime in the late 60's.
sorry I missed this thread .....
Motor Wheel Corp. plant #1 is Lansing & plant #5 is in CANADA somewhere?
I usually type the stampings as: M1/8 6 -o- 17 LS
M1 = Motor Wheel Corp. plant #1 Lansing, MI
8 = 1968
-o- = valve stem
6 = June
17 = 17th of month (Monday, June 17, 1968)
LS = application (on a '68 14x6.0" SSII)
Some of the Mopar (& other?) wheels have 6.0, 5.0 or 5.5 (wheel width) instead of an application code.
8 = 1968
-o- = valve stem
6 = June
bolt pattern
happy new year, i was just wondering while you are talking about rims, did they not change bolt patterns every three years or so? and wouldn't at least any of numbers pertain to that or no? just wondering. i have a 64 and mine came with mags on it and 15 inch rims and know it should be 14teens, i am going to shitcan the mags and get originals steel rims. so reading these posts have helped. thanks
I have 4 people here saying that Sammy's HF is a disc brake code. I must be blind in one eye and can't see out of the other, because my PIM says it should be HB, not HF. I don't see a HF code for '68.
Where are you getting the HF information from?
I also have a number of wheels to get pics of and numbers off of, so stay tuned!
I think the HF rims were used on late 60's to early 70's GTO's disc brake rim, standard steel. Maybe others.
Kurt, do you have any HF coded rims? If so, what is the offset?
I have not had time yet to go though my wheels since we picked up this discussion, but I still plan to.
I have the same info as you that the XE code is '68-'69 Chevy.
Are those codes exclusive to a make?
BTW, I'm still looking for an answers to my #26 post:
"I have 4 people here saying that Sammy's HF is a disc brake code. I must be blind in one eye and can't see out of the other, because my PIM says it should be HB, not HF. I don't see a HF code for '68.
Where are you getting the HF information from?"
It appears this same rim was used on some 442's in the 65-67 era with a code of R and made by KH and NT; however, Motor Wheel also made a rim coded R for 442's of this era coded R with a slightly different center section (cut out area) and a different outer hoop.
I have been told by quite a few sources that the HF is the code for 68-72 pontiac GTO'S 14x6 disc brakes, Maybe chevelle ss also. I have personally had numerous HF rim and they were made by Motor Wheel, NT, and KH. Depending upon the year and the manufacture there was a minor difference in the cutout areas. A flat looking cutout as opposed to a curved cutout. See the photos, both rims made by Motor wheel in 1970. Only difference is the offset, 1.00 and 0.88 respectively
What is you PIM? Is it the same as a Chevelles AIM or assembly instruction manual? Or is it like a Chevelle build sheet. I have no reason to think the 68 olds code is a HF other than the previous posts. Awaiting what you have to report after looking at you other rims.
Henry
I've attached the wheel code page for 1968. Note that '68 was the last year for the R code for Olds, and also note the HB disc brake wheel code. These codes are also what show up on the Olds build sheets in the wheel code box.
It is important that we realize that these are "application" codes used to identify what wheels go on what cars in the manufacturing process. It is not a code to identify all of the wheel detail. Meaning there *may* be differences in wheels with the same code. Of course if there is, it would theoretically be minor and insignificant to the manufactures engineering dept.
I know that is a "fine line" of difference, but it is important when we get down to this level of detail. Plus we are working with a *lot* of second hand information.
from a couple '67 Oldsmobile build sheets
February 1967 Fremont built Cutlass Supreme w/442 convertible:
BOX 45 WHEELS “R”
BOX 108 TIRE DESCR “F70x14 N/R,S 2
BOX 109 “N81 F70x14 2PL 4PR”, “N95 SIM WIRE WHLS” & “P12 HD WHEELS”
February 1967 Fremont built Cutlass Supreme Holiday coupe:
BOX 45 WHEELS “A”
BOX 108 TIRE DESCR “775x14 R/W/W 2
BOX 109 “P01 WHEEL DISC” & “P26 STD WSW TIRES”
BOX 45 WHEELS “R”
BOX 45 WHEELS “A”
Is it possible that the Oshawa plant was using up inventory?
I cannot see it being coincidence that the car has all 5 coded steel rims, whose manufacture date were 5 weeks before the car was assembled.
Another interesting item is the XE rims came from an all drum brake 1970 Cutlass, and it also had all five the same code/manufacture dates....
Your speck sheet Kurt was dated Aug 1967 and was first used in 1968. I assume that would be starting for the 68 model in Sept of 1967.
That said, there are changes that were made during the year, and the revision ledger and revision notes may or may not reveal what was there with previous releases.
Sure any plant could (under some circumstances) use up stock, but that certainly was not the norm. Little of that is documented.
I'm not at all suggesting your wheels did not come on your car originally. But as you can see for yourself, the factory docs say the code for your 68 was HB. I have not looked everywhere, but I don't know what the HF is supposed to be for. (I'll ask a stupid question, are you sure it is HF and not HB?) Never the less, if your wheels are correct size/configuration-wise, they very well may be original.
HF first shows up in '70., part number 9791450. It is not the 442 wheel in '70-'72(at least), because I believe the all the 14" wheels (sport and steel) were 14" x 7".
Bottom line is that I don't show the HF code wheel to be correct for the 442 for any year.
Here is what I found last night regarding steel rims.
65-68: Code R for 442, (14x6).
67-68: Code HB (14x6), showed up as disc brake for use in 67 to 68.
69: Code LR, (14x6),for 442 & S.W., and for disc brake option, gm 403397
70: Code XT, (14x7) for 442.
Code HF , (14x6), for all disc brake (exc 442 & sw)
Code XE, (14x6), for all exc 442 & sw
Code LR, (14x6) for S.W.
71: Code XT (14x7), for 442
Code HF (14x6) for all others (exc 442 and sw)
Code MH (14x6) for S.W. 14x6
Interesting to note that I found a 67 tempest document on wheels showing.
HB code showed up as a disc brake rim and had same part number as HB in the olds document, gm 9773690. So both Pontiac and Olds used the same rim in 67. likely to assume this happened with other codes and though Chevy and Buick to some extent.
Also in the garage I have HF rims from Motor Wheel, Kelsey Hayes, and Norris Technologies, so likely to assume all three manufactured wheels to all gm divisions. I also have some MH rims and some XE rims, which appear to be exactly the same. XE is the code for late 60 chevelles and now I find MH used for olds.
