Click Here
help with wheel specs..
Old Feb 17, 2014 | 01:48 PM
Carl, uk's Avatar
looking to purchase a new set of 15" full chrome smoothie rims...
iv measured my existing rim,,, 5x120mm 76mm centre bore,, what offset would you recommend...??? im sure zero offset is standard,, i realy want to fill out the arches more so do i go with a different offset or a wider wheel ??? any advice/help is greatfull.... thanks..:
Old Feb 17, 2014 | 04:53 PM
Um, what car would these be going on? That info is kinda useful for folks to help you determine how wide a wheel will fit without rubbing.
Old Feb 18, 2014 | 01:12 AM
Carl, uk's Avatar
what a dumb **** i am,, 1973 delta 88
Old Feb 18, 2014 | 01:17 AM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
Originally Posted by Carl, uk
5x120mm
Be careful, European!
That's 5x 120,65mm (4,75 Inch)
While for example BMW rims with 5x120 will "fit", you might brake something or everything - bolts, studs, rims, your neck - sooner or later!
Ed: Wasn't that even 5x5" in 1973? You measured it, you'll know.
Old Feb 18, 2014 | 05:44 AM
Carl, uk's Avatar
Absolute correct fitment is gonna be 5x127mm with a 3mm offset to give the wheels a deeper dish, going for 15x7" crager traditional smoothies...
Old Mar 23, 2014 | 05:10 PM
pmathews's Avatar
This website helps you compare wheel/tire combos, it's super helpful and worth a look ->
http://www.rimsntires.com/specspro.jsp
Old Mar 24, 2014 | 01:51 AM
Carl, uk's Avatar
Thanks for your help. Bought some full chrome deep dish smoothies...
Olds442redberet
Dec 27, 2014 03:14 PM
66ninetyeightls
Ninety-Eight
Jul 17, 2014 05:03 AM
stuhes
Wheels and Tires
Jan 19, 2011 06:35 AM
lil_no
Body work
Aug 6, 2009 09:39 PM
Big Dave
Dec 15, 2005 12:02 PM
