Click Here
255/60-15 Tires
Old Oct 19, 2014 | 10:24 PM
anthonyP's Avatar
255/60-15 Tires
Will 255/60-15 tires on factory 15x7 SS-II rims fit all the way around on a '70 442 without rubbing?
Old Oct 20, 2014 | 01:04 AM
Magna86's Avatar
Yes from my experience. I run them on my 15x7 SSIII's. No rubbing I can tell unless its on my bigger front sway bar at full lock. Haven't driven car much since rebuilding suspension.
Old Oct 20, 2014 | 07:13 AM
I've got BFG 255/60-15s on the factory SSII wheels on my 69 H/O. I get a very slight rub when I hit a bump with the wheels at full lock, like when turning into a driveway. Otherwise, no issues whatsoever.
Old Oct 20, 2014 | 09:11 PM
anthonyP's Avatar
Thank you for the responses. I will go with the 255/60-15 tires all the way around. According to conversion charts I've seen, the 255 tires are suppose to be equivalent to G60-15 tires, the size Oldsmobile was going to install as an option on the '70 442 & Cutlass, before it was cancelled for some unknown reason.
kstern58
Wheels and Tires
25
Dec 26, 2014 07:25 AM
Wheels and Tires
Oct 22, 2013 10:31 AM
nonhog
Wheels and Tires
Feb 22, 2012 11:00 AM
The Stickman
Feb 11, 2011 03:00 PM
cutty
Nov 25, 2008 07:17 PM
