255 on 7" rim ?
255 on 7" rim ?
I've tried to find charts on Google and I always get the one that asks for the original tire size. (Who cares?)
I just want a beefy look to my 65 Cutlass rear tires. I also want it to work properly.
I will of course fit the wheel 1st then see about the tires.
So anyone know of a chart that is basic?
TIA!
TIA!
I'm sure you would not stretch a wrong size on your car, so that helps!
I ended up with some 15x7's off a 76 Monte Carlo standard steel wheels.
I thought I would get rid of the Corvette wheels that rub in front.
I'll test fit them w/o tires and see how the backspacing works for the 65 Cutlass. Not sure if I want to run them in front or use 14's in front for a big/little vibe.
Big question was 255 or ? Looks like that'll be my plan.
According to Tire Rack specs for 255/60R15 BFG's the rim range is 7-9", so should work fine.
http://www.tirerack.com/tires/tires....omCompare1=yes
I just put 255's all the way around on 67 Delta 88... but I went with 15x8 rims.
Wheels and Tires
Oct 22, 2013 10:31 AM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
81 regency
Apr 21, 2011 06:18 PM
