Click Here
65-70 Big Car 15x8 wheels?
Old Oct 27, 2015 | 08:22 PM
cfair's Avatar
My 66 Starfire front tires are squealing & old. Currently running 15x7, but since I need new tires, I'm thinking about going to 15x8 all around for slightly better handling with a factory look. 14x6 was factory, but I'm well past that already.
Do any of you do this? I'll need 15x8 on a 5x5 circle (not cutlass 4.75x5 circle). I like the SSI's, so if I could find them & center caps in a 5x5 15x8, that'd be great, but I think that's custom.
So I don't know where to buy the wheels. My mechanic said 15x8 are truck wheels. Suggestions? I've built some custom-ish 15" Olds 3-bar spinner wire hubcaps I'd like to reuse, so just a factory style wheel and those 'caps will fit would be great.
Also I'd like to get a sidewall profile to get to more or less the outer diameter that Olds did in '66 to get the speedo to read right. I think this means low profile, but I'm still ignorant about tires after 35 years. Sorry...
On top of that wide low profile business, I'll be adding a 3/4" whitewall for a period look. There's a company in NC that does that, so no problem there. Anyway, looking to share your wisdom, suggestions?
Old Oct 28, 2015 | 09:14 AM
orange442's Avatar
The only factory steel 15x8 wheel in a 5x5 pattern is the Chevy truck rally wheels. They will accept a full hubcap like any other steel wheel which sounds like the way you want to go with the 15" 3 bar wire hubcaps you mention. These wheels are easy to find and are a direct bolt on 5x5 pattern. The largest plain steelie wheel was only made up to 15x7 from the factory.
olds70supreme
May 16, 2022 06:31 PM
doc
Dec 28, 2017 10:06 AM
501Paratrooper
Wheels and Tires
Jan 18, 2014 11:35 AM
yankees
Wheels and Tires
Sep 10, 2012 06:53 AM
toro68
Mar 28, 2009 01:36 PM
