Click Here
Wheel tourque
Old Jun 24, 2014 | 11:55 AM
bapa1944's Avatar
Wheel tourque
Anyone know the wheel tourque for a 1963 Olds super 88 ?
thanks
Old Jun 24, 2014 | 12:36 PM
TIGHT.
Nobody checked the torque on lug nuts on older cars. That came in with the Japanese, disc brakes, and alloy rims.
If you must know, though, the Service Manual says 70-85 ft-lbs.
Old Jun 25, 2014 | 07:54 AM
HWYSTR455's Avatar
Well, technically, it came in when hubs and rotors went 2 piece, since you can warp a rotor if not equally tightened.
Old Jun 25, 2014 | 08:21 AM
66400's Avatar
Originally Posted by MDchanic
TIGHT.
And in other words the lugs on wheels install by the 300# man will be tighter than the lugs installed by the 120# lady!
Henry
Old Jun 25, 2014 | 08:55 AM
Octania's Avatar
Watch for LH threads on the LH side of the car too.
Typically stamped "L" on the end of the stud
Old Jun 25, 2014 | 09:53 AM
I use 95-105 on most wheels.
Old Jun 28, 2014 | 08:34 AM
D. Yaros's Avatar
Is not the '63 like 1962 in that the studs have left-hand threads so that they tighten as the wheel rotates? If that is so, is torque critical?
Old Jun 28, 2014 | 09:07 AM
oldsguybry's Avatar
NOVICE car nut
Really ?
CutlassS1972
Body work
Aug 21, 2014 09:06 PM
johnnyjaws
Aug 17, 2014 09:13 AM
