Click Here
Widest tires for '69 Cutlass with 10x15 wheels?
Old Feb 13, 2015 | 03:17 PM
yamahondarider's Avatar
Hey guys, I picked up a set of 10x15 wheels at a local swap meet last fall and would like to put some new rubber on em for my Cutlass for spring time. They have a 3 inch backspacing. Whats the biggest tires I can fit in the stock wheel wells of a 1969 Cutlass? Stock suspension stock differential, all sheet metal unmodified. I'm looking at slicks such as the ET-Streets or possibly a tire like the Sportsman Pro or even a 10.5w drag radial. What are you guys running?
Old Feb 13, 2015 | 04:35 PM
Mr Nick's Avatar
Yikes, unless you jack up the rear suspension I don't think they will fit at all.
I believe factory wheels had about 4" backspacing on a 7" wheel. So the outside of your wheels will be 4" farther out than stock.
Old Feb 13, 2015 | 05:23 PM
Rallye469's Avatar
I don't know '69's, but I think Nick's right.
That 3" of back spacing is gonna kill you.
I think my 15x10's have 5.5" of BS and they barely fit.
-Pete
Old Feb 14, 2015 | 11:10 AM
pmathews's Avatar
I'm guessing the prior owner ran these with a narrowed rear end, from my calcs, it's going to stick 2" out the sides of the fender. Take a look at this calculator and check for yourself: http://www.rimsntires.com/specspro.jsp
You need a lot more backspace to run 10" wheels, like 5.5"
Old Feb 14, 2015 | 02:38 PM
oldsmobiledave's Avatar
fyi
You can run a 275 60 15 drag radial on an 8" wide rim with 4-4.25" BS on a 68-69 Olds A body with the original or same width differential.
Do you really need more tire than that?
Old Feb 14, 2015 | 02:42 PM
With 500+WHP on the street? Your damn right I do! . Plus a big part of it is for looks too.
I'd back half it and run a Ford 9 inch and 18.5x33's if I had the cash. This ain't no sunday car show cruiser.
Old Feb 14, 2015 | 03:00 PM
last thought
There are plenty of guys making more power than that who compete with the 275 60 15 Mickey Thompson drag radial. Don't knock it until you try it.
Old Feb 14, 2015 | 03:02 PM
I'm not really interested in the smallest that works, more so in the biggest that fits, period. Not just for performance but for looks. I want fat tires on my '69.
Old Feb 14, 2015 | 05:47 PM
Mr Nick's Avatar
I have 285/40/18's and they fit up in the wheel well, with the lip rolled. I actually have a little room to spare on the frame side.
So, the 275's will fit as suggested. You may be able to get a 295 in the back with the right rims, but not with what you currently have.
I think MT makes 295/55/15 (28" tall) drag radials.
jnaarnold
Sep 12, 2017 08:09 PM
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
WTony
Jan 15, 2011 07:53 PM
jtriggy
Wheels and Tires
Feb 22, 2010 05:47 AM
