- BF Goodrich question
- 68 442 tires..whaddayathink?
- Custom wheel backspacing question?
- Tire size
- 1987 cutlass salon tire sizes????
- Best place to find rally wheels for a 72 Cutlass?
- Specialty Wheel 15" SSII Wanted
- 4 stock 14 inch rims and hubcaps off 68 make offer
- 1955 bolt pattern help please.
- intresting problem
- Locking Lug nut problem
- Can someone identify these wheels?
- Wheel Vintiques 58 Series Backspace Question For 71 442
- another large tire 305/45/18 question
- photo gallery?
- New Spinner Hubcaps for my '57 and new valve stems
- Repro trim rings/caps/bezels for 15x7 SSIII rims
- 66 Toronado spare wheel is BIGGER?
- Correct 72 442 Vert Tires?
- SSI's or Cragars?
- 1980 Cutlass 195/75R14?
- 14inch rally wheels for 15 inch
- HELP! Left Hand Thread Lug Nuts
- 245/60/15's on front + 1" lowering springs... rubbing?
- Will these fit?
- Wheels.
- 66 442 tires
- Staggered Look
- Strange wheel question...again
- 68-72 A Body w 295/65/15's ?
- Painting rims separate or with tires on?
- 14X7 LZ Code Wheels
- Joline needs new shoes,..help with sizing??!
- Fronts 245/45/18x8.5" 5.7 BS, 25mm offset
- 20" rims on 69 Delta...will this work?
- Resto tire size
- This Olds needs new shoes...
- Can you ID this Wheel?
- American racing mag wheels proper size
- Will a 10" wheel fit a 70 model without rubbing?
- 66 Olds wheels
- Orginal '76 Cutlass Rally Rims
- '62 Olds 98 hubcap clips
- Is this a '71 Olds SSI chrome wheel?
- What's the proper tire size - '62 Ninety Eight w/AC
- Donut vs full size spare
- Good or bad deal on set of SS rims?
- Looking for wider wheels
- Steel wheel correct color confusion
- Different rims and same tires...need an alignment?
- Sand blaster help.
- 80 cutlass tire size?
- offset olds 98 1972
- 1970 cutlass a-body largest tire?
- Show me your fullsize wheels!!!!!!!
- N.O.S. Oldsmobile Toranado Hubcaps
- 1972 cutlass supreme boltpattern/wheel dimensions
- opinions on Super Stock I (SSI) center caps
- Correct Color of SSII wheels - 1970 442 convertible
- bolt pattern on '69 F-85?
- bolt pattern for 69 F-85?
- Super Stock III centercap retainers?
- Biggest 15" tire for 87 Cutlass Supreme 4-door
- best wheel/tire combo for my 71 cutlass
- Will These Tires Work?
- Can someone tell me Brand & model of this wheel?
- 67 Vista Cruiser - new wheels
- '67 442 Convertible Rims/Tires
- 62 F85 what size15tire fits
- Tire balance issue?
- 56 Deluxe Spinner Wheel cover
- What are they worth?
- How the hell...
- Tire Pressure
- 15's on a 66 Cutlass
- Centerline wheels with almost new tires (trade)
- 15x7 SSII Wheel Weight without tires
- 215/75B15 2ply tires
- Looking To Buy New Tires For 15" Rally Wheels Your Ideas Count
- How would I know what wheel size my Cutlass has
- ID wheels
- Wheels
- 1952 wheels
- setup for my 75 cutty
- Clueless on wheels/tires
- 1957 88 Tire Guru Needed
- 68 Cutlass Argent + Silver Paint
- Why ruin a beautiful new car??
- Wide Tire
- 15x8 cragar s/s
- Self-destructing spare
- chrome super stock I wheels
- Will these Cutlass rims fit my 67 Cutlass
- Cheap lift for 1985 cutlass supreme?
- Wheels for a 64 starfire
- Classic white wall tires?
- Good wheels for my new cutlass
- Which tires?
- wheels?
- back space question
- 1970 Wheel Disc Photos
- Sleeper drag tires, Futura ?
- tire size?
- Painting SSI Wheels
- Beauty rings stolen
- To stagger or not to stagger
- Wheels upgrade
- SSII Price
- 15 inch SSII Bolt On Centers
- 68 Delmont 88 rims
- Torq Thrust Wheels
- 1968 Cutlass Disc brakes wheels
- Cooper "Private Name" Brands "El Dorado" & "Cordovan"
- 15x10's on the back of a 1969 Cutlass S
- 1966 Olds Delta 88: Rim Ideas
- Scored On A Set of Cragar SS. What Tire size should fit??
- Original Rim size 74 98 URGENT
- 15x10 on '65 f-85 rear
- P225/75R14 Tires-63 Starfire
- free 14x7 with ring and centercap
- taller tire
- Wheel Widening
- Can anyone help
- tires for '65 f-85
- Decided to go retro..(im poor)
- 70 delta 88 2 door rally wheels
- Rally wheels for 1968 442?
- Tires for '70 olds 442
- Wheels that fit.
- Extended wheel studs.
- Time for new tires
- 245/60/14 Will they fit & how will they look?
- Bias vs Radial for 1950 88???
- Would these fit?
- For Sale 14" SSIIs VGC
- 15' Oldsmobile Rally Wheels
- Mickey Thompsons
- Wagon wheels?...
- Wheel update - took off the 22s
- SSIII Stamping decode and differences in D shaped Ring ???
- Wheel/Tire Suggestions
- Whats it worth... Complete set of SSI's
- Cener cap emblem
- 69 cutlass sedan
- Tire Sizes???
- Sanity Check Toronado 1st Gen OEM Chrome Wheels
- Rally Wheels
- chrome 15x7
- rim help
- Correct size radials for my '68 4-4-2
- 14"x7" drum brake wheels fit on disc brake?
- 15" SSIII questions
- Show me your wheels!
- Wow Wxpensive 15 x 7s Bolt on
- Should ss1's have trim rings?
- Downright Scary!!
- 69 h/o wheels
- 18" wheels
- 15x7s?
- Wheel value help?
- SS1 Centre caps
- wheels on fleabay
- tire size chart
- 1969 wheel ?
- Anyone know about 1950 wheel specs???
- What stock tires are these?
- Wheel Cylinders
- Another tire size question
- 75 cutlass supreme tires.. TA's??
- SSI's swap meet specials
- Rims for 68 cutlass
- Largest wheel/tire on the rear of '66 F-85
- Wheel size for 1955 Super 88
- Finding Fifteens that Fit...
- Can anyone identify this for me?
- restoring rims
- 15" SSII Bolt on centers
- Six of one, 1/2 dozen of the other...
- White wall tires
- Olds SI vs. Buick Ralley wheel
- ss11 center caps cleaning
- Go 'BOOT YOURSELF'!!!
- SSI center cap interchangeability
- Is G70x14 bias ply a proper match with 14x6 rim? flat spots?
- Original Equipment Tires for 1960 Olds
- Center cap decals
- Snap-on Center Cap Ornament Question
- Olds hubcap ID... Fiestas?
- Is my tire salvagable?
- 14" tire question
- 15x7in olds ralley wheels
- 62 Starfire Wheel Covers
- Tire Size for 65-6 Fullsize
- Stock Wheel/Tire Size for 61 98 4 Door HT
- Correct lug nut size on 68 Cutlass Supreme?
- 17" wheel question for 71 cutlass S
- SS1 Rim Basics Question
- biggest tire size ?
- What size tire for 15x7 ssII rims?
- N98 Chrome wheels
- 14" SSII Rims
- Anyone run 24" rims on cutlass??
- 64 Cutlass-biggest on 14x6?
- Resto rims
- 67 offset..
- Will tires rub?
- Wide Ovals/ Polyglass
- Anybody know.....
- 15 Inch SSII
- wheel id
- New wheels or lift kit?
- 17" or 18" SSIIs?
- American Racing Wheels on 68 Cutlass Supreme
- '72 Supreme wheel covers, are they shaded?
- Will these wheels fit a 67 Cutlass
- wire spoke wheel covers ,
- help...suspension issues
- Correct Size Tires
- 72 Toronado wheel size?
- 1972 SSII wheel color
- Tire question
- 70 Toro GT Tire size?
- 15 inch trim rings - which ones
- 15" Rally Wheels For 69 Vista
- SSI 5x10
- Rimz n tirezzzzz........
- 58' Olds 98 Super 88 Sedan
- Question about rims and backspacing.
- Wth &%?!!!
- 33 Olds wheels wanted
- What SS3 wheel am I needing?
- Proper way to balance SSII wheels.
- Where can u find p235-70R14
- Tire
- winston winner tires
- tire size 1969 olds 88 delta
- Keeping Hubcaps On
- SS3 trimrings
- Thanx to TireRack
- 1965 Cutlass correct tire size
- 57 Tire Replacement
- Scored me some rims!
- Widest Rim size for 1970
- 66 442 Tire size ???
- Wheels and tires for Gbody
- 17 to 18in is it worth the extra 1000 bucks
- Limeys wheel choice w/ installed pics
- Wheel Size Help
- Tire Trauma
- chrome ralley wheels what are they worth
