68 Delmont 88 rims
68 Delmont 88 rims
I have 68 Delmont 88 that had 855/14 tires. When I updated in 1988, A tire guy suggested radial tires but I had to find 15 inch rims. the rims are off of a 1972 88. He mounted 235/70/15 cooper tires on them. I found out later that the rims are 6.5 inch so the mounted tires are wider and not nearly as tall. I now want to go to 16 inch rims but I do not know what rims will fit the bolt pattern. It is about 5'' accross and a 3" ? center. I couldn't find the original measurements anywhere. What year rims will fit and how tall can I go in the rear wheel well to improve milage. The original 855/14 tires were 82 ? I think. I'll leave the front the same diameter as the original 29.1'' to keep the speedometer accurate. Ken
google is your friend...
http://onlyoldiesgarage.com/xcart/pr...roductid=16301
https://www.rsracing.com/tech-wheel.html
Chevy or GMC pickup/van (5-lug) wheels will fit.
Unfortunately, I think even the 2-wheel drive trucks went to a 6-lug hub about the same time 16" wheels became common.
94-96 Chevy Caprice police cars had 16" steel wheels.
wheels for my 68 Delmont 88
I just went to the garage and measured the rims. The bolt pattern is 5 X 5 with a 3" center. I have Cooper 235/75/15 tires on it. The rims are 6" wide. I need to go to a 7" rim. The SS II and SS III didn't come with 5" bolt pattern. I think the SSI rims came in 5X5. I might have to go that way. I want to be able to put a taller tire on the rear for better milage. Any ideas. Ken
are you wanting a taller tire or taller rim? you are kind of all over the board here and not quite answering the questions that are asked.
I'm also confused about the "going with a taller tire to improve mileage" comment. you don't always need a wider rim as sometimes you can go taller with a tire size while keeping the width the same. Again, a Google search of "tire size 101" may be helpful to you.
and as I have stated many times in this thread, Google is your friend.
68 Delmont 88
I GOOGLED gm bolt pattern chart. They did NOT show my vehicle. I want a taller tire but most of the taller radial tires require a 7" rim. I GOOGLED a tire size calculator and most of the tires that would work are 16's. I just want to put the taller tires on the rear. A 2'' taller tire will increase my mpg about 10%. I've got room to go with a 3" taller tire and still have plenty of room with 5 adults and 150 lbs in the trunk before the bump stop comes into play. Now do you see where I am going? Thanks in advance for any help. Ken
thanks for the anger, I'm only trying to help.
what I meant was you can Google how to measure bolt pattern and then go out to your car and measure it. more than likely its going to be 5 on 5 or 5 on 4 3/4. From that you can start searching online for what vehicles came with what you are looking for.
I have a set of 4 factory steel 15x7 wheels in nice condition that came off a station wagon that might work for you. A 255-70-15 tire works well on a 7" wheel and would give you a nice tall tire.
