Click Here
Which tires?
Old Jun 23, 2011 | 01:39 PM
442b's Avatar
Which tires?
I
Old Jun 24, 2011 | 07:02 AM
Originally Posted by 442b
I just bought a 1985 Oldsmobile Delta 88 Royale Brougham and I need to replace the 215/75/R15 tires. The door jam sticker calls for 205/75/R15's but I'd like to go wider because there is room & it would provide better look & ride. Thinking to stay with the white walls since the car is a 4-door & painted white with maroon interior. Also, it has 39,000 original miles on it & I'd like to keep it as close to factory as possible.
Any suggestions on Which Tire Brand may look & ride well on this vehicle?
Suggestions from actual owners would be very helpful. Maybe a picture or two also.
Thanks for the help.
The stock 205/75-15s would be 27.1" in diameter.
Your 215/75-15s are 27.7" in diameter.
I'm running 235/70-15s on my 84 Custom Cruiser. These are 27.9" in diameter.
You could also run 235/65-15s, which would be 27.0" in diameter, nearly the same as the OEM tires but about 1" wider. Unfortunately, I have not found a source for that size tire. I'd suggest the 235/70s, which are readily available from BFG. I have no problems with them on my 84. Your speedo will read about 3% slow due to the larger diameter.
olds 307 and 403
Wheels and Tires
20
Jan 29, 2017 03:16 PM
Creativeindy
Wheels and Tires
Sep 6, 2012 07:52 AM
snowballs442
Wheels and Tires
Apr 28, 2011 02:26 PM
Mister
Wheels and Tires
58
Oct 27, 2010 04:57 AM
Gaz Hog
Jun 29, 2010 08:44 AM
