Click Here
Cheap lift for 1985 cutlass supreme?
Old Jul 4, 2011 | 09:55 AM
jaimesupreme's Avatar
Question Cheap lift for 1985 cutlass supreme?
my cutlass had 22 inch daytons on but i took them off because it got cold and because the tires would scrape against the body and the tires would rip. i want to lift it just enough so i could put people in the back and Passenger and not worry about the scraping or tearing of the tires. i was thinking of putting air shock in the rear and front shock extension in the front. does any one know if that would work and how much of a lift it would give? thanks
Old Jul 4, 2011 | 09:44 PM
Redog's Avatar
More importantly:
Did you upgrade the, brakes, rear axles, and the A Arms as well? Since these items will fail with all the weight and stress of those heavy wheels
Old Jul 4, 2011 | 10:45 PM
svnt442's Avatar
No....can't.......speak.......
Old Jul 5, 2011 | 02:17 AM
jensenracing77's Avatar
wouldn't it be easier to pull the body off and put it on a truck chassis?
Old Jul 5, 2011 | 03:00 AM
Smile
Originally Posted by Redog
More importantly:
i did all that already thats where all my money went to but u think it could work with all the stuff i said? thank you for replying by the way
Old Jul 5, 2011 | 11:31 AM
Redog's Avatar
Glad to hear you are doiong this the correct way Although I'm not a fan of doing this
There's got to be DONK forums you can find out this info. Maybe longer springs and shocks with larger bump stops would do the trick. Don't know if it's going to be cheap thou
Old Jul 8, 2011 | 05:11 AM
made in the usa's Avatar
Old Jul 8, 2011 | 12:04 PM
Redog's Avatar
Personally, I think it's stupid to do this, however, this guy says he upgraded all the parts from stock to something better, esp the brakes, so I'll help out as much as I can, althought I don't know much about this topic.
If it had stock brakes, axles, a-arms, etc, I wouldn't be helping
jensenracing77
May 1, 2009 02:35 PM
POKANOKET
Jul 14, 2007 02:58 PM
LDavis
May 17, 2007 02:15 PM
TECH9TWISTA
Apr 24, 2007 07:22 PM
Grinder89
Sep 15, 2006 08:16 PM
