Fronts 245/45/18x8.5" 5.7 BS, 25mm offset
Vehicle: 1971 cutlass, has Hotchkis tubular front upper and lower A arms with 1" hotchkis Big Block drop springs and extreme sway bar up front.
I would like either a 245/45/18 or a 255/40/18, what are the recomended wheel backspace specs for this size tire/suspension?
I found a wheel/tire combo of 245/45/18x8.5" 25mm offset with a 5.7" BackSpace, will this size rub the fenders/frame?
I found this cool database and punched in these numbers, does these numbers sound correct? should I lower my offset to 19mm and BS to 5.5"?
http://www.rimsntires.com/specs.jsp
oldzy
Wheels and Tires
Nov 23, 2011 04:37 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
81 regency
Apr 21, 2011 06:18 PM
