Click Here
cragar ss wheels
Old Apr 30, 2015 | 11:18 PM
Foss604's Avatar
cragar ss wheels
Hello, Im very new to all this and want to get a set of cragars on my 1964 f85 cutlass. I found a set on craigslist but I'm not sure if they will fit,any help would be greatly appreciated. The rims specs are as follows
2- 15"X9" with a 4.25 "backspace
2-15"X8"with a 4.25"backspace
They are uni lug 5x4.5 and 5x4.75 bolt pattern
Thanks again
Old May 1, 2015 | 07:52 AM
rocketraider's Avatar
Oldsdruid
The unilug bolt pattern will be OK; you may have to find the special washers and shank lugnuts for them.
Not sure if 15x9 will fit under your rear wheel wells. Cutlass rear wells were a little tight thru about 1969.
Old May 1, 2015 | 10:37 AM
Foss604's Avatar
Thank you sir.I will continue doing some more homework.Im hoping they will fit its a good deal!! cheers!
Old May 1, 2015 | 01:13 PM
Thanks again
15x9 wheels will fit fine. It's the TIRES that will be the problem... Since you didn't tell us the expected tire size, we cannot offer useful information.
I will note that only 4.25" backspace on a 9" wide wheel means that you have about an inch of negative offset. That means that the wheel will be pushed towards the outboard edge of the wheelwell, and for any tire you typically would mount on a 9" wide wheel, you will definitely be rubbing the wheel opening lip. You want as close to zero offset as possible, so that means about a 4.75" or even 5" backspace on a 9" wide wheel.
Old May 1, 2015 | 07:12 PM
classicmuscle442's Avatar
Not a fan of the uni-lug rims, always work loose.
Old May 2, 2015 | 12:38 PM
oldstata's Avatar
Justin
Here is a shot if 17x9.5 with 225 55 tires on I am going to put some 245/55 on just want to check with crappy tires before buying these have 0 offset
These are on a 65 cuttlass
Old May 6, 2015 | 10:48 PM
Foss604's Avatar
MY bad guys.The tires are Grand AM Radial GT's 2x 235/60 15's and 2x 275/60 15's
Thanks again this is all a great help to me.Ive learnt quit a bit form just reading through different threads. At the end of the day these Cragars will fit? The rubber on the other hand may be too big?
Old May 6, 2015 | 11:38 PM
GoodOldsGuyDougie's Avatar
Do yourself a big favor and buy new Cragers SS Rims. There still a damn good deal new. Better to start off with something new, that you know will work for your exact needs. Summit has them and you can catch deals once in a while on line. Good luck and nice choice for your car. Nothing looks better!
Old May 7, 2015 | 08:11 AM
orange442's Avatar
I do not recall the Cragar SS being made in a 9" width. I have had many 7", 8", and 10", but no 9". Are you sure they are being measured correctly? Wheel measurement is done from bead to bead not lip to lip. If they are being measured lip to lip they would be 7" and 8" measured correctly. Also recheck back spacing as that seems a little off as well.
Old May 10, 2015 | 05:24 PM
Foss604's Avatar
Cheers good old guy dougie, it looks like thats the route i will take.Going to buy them new!! Thanks a lot everyone for all your input.Much appreciated.Enjoy the weekend cruising!!!
Old May 10, 2015 | 05:37 PM
Bernhard's Avatar
Is that your HO ?
Nice car
My friends give me a hard time about liking the Crager ss rim, but I feel it is period correct and looks much better than the modern over size rims with next to no side wall.
I would buy new also with the correct off set and bolt pattern.
Good luck
Old May 13, 2015 | 11:23 PM
Yes on the Car. Tires are Bias Ply as well. It Gives the car the exact look to land it back in 69.
Old May 14, 2015 | 12:46 AM
Bernhard's Avatar
Yes on the Car. Tires are Bias Ply as well. It Give the car the exact look to land it back in 69.
What size tire are you running in the
back they look sharp on the car.
The car is sweet
Old May 14, 2015 | 05:40 PM
The Tires are Competition Series Pro Trac
The front are P215-75D15
The Rear are P275-60R15
Purchased from Summit with the Crager rims. There was a back space on the rear but I can't remember what it was at the Moment. They Shipped to my house already mounted balanced and ready to Install. I'll try and post a rear shot so you can get a better idea what they look like from behind in a couple of days.
Old May 17, 2015 | 05:45 PM
jerseyjoe's Avatar
If you don't want to deal with the slotted lugs, I have the Cragar Chrome Eliminators on mine with 245-60-15 tires. Everything fits nice and they are close to the classic cragar look.
Old May 17, 2015 | 08:11 PM
Bernhard's Avatar
They make direct fit ss wheels now
bills65olds
Wheels and Tires
Dec 11, 2012 05:37 PM
oldspackrat
Sep 4, 2012 06:36 PM
richyrich
Feb 6, 2011 04:40 AM
DAN76
Oct 20, 2008 06:24 AM
tiparosa
Jan 24, 2007 03:19 AM
