tire size question
X2. I've run that tire size on all four corners of my 69 H/O, on the factory rims, and it does rub slightly if I hit a bump at full lock (as in, hitting the dip at the end of a driveway). The 64-67 cars have slightly smaller wheelwells than the later cars, so the problem is likely to be worse.
I'm running 235/60 x 15 on the front of my '67, and they are too small. I'll be trying 245s next time or maybe a 70 series that's taller.
I'm running 275/60 x 15 in the back, and they fit great. In my '67, I could probably go even larger on the back, there's plenty of room in the rear. My 275s are 28" tall, and they never scrub.
I believe Eric is running a taller tire in the front, that might be an option (vs. wider). The 235s don't fill the wheel well in my car, but if they were a 70 ratio (vs. the 60), it would look nicer. I believe Eric is running a taller tire. The 235/60s are about 26" tall. 235/70s are 28" tall, 225/70s are 27" tall (approximately).
