Click Here
tire size question
Old Mar 16, 2015 | 06:32 AM
Sea five's Avatar
tire size question
Ready to buy tires for my 67 442. I. thinking of running 255/60 x 15 all around. Concerned about turning clearance. Thanks
Old Mar 16, 2015 | 06:36 AM
From my personal experience, depending on the condition of your front springs, putting that size tire on the front may rub at the rear of the wheel well when you hit a dip.
Old Mar 16, 2015 | 07:19 AM
X2. I've run that tire size on all four corners of my 69 H/O, on the factory rims, and it does rub slightly if I hit a bump at full lock (as in, hitting the dip at the end of a driveway). The 64-67 cars have slightly smaller wheelwells than the later cars, so the problem is likely to be worse.
Old Mar 16, 2015 | 11:07 AM
Sea five's Avatar
Thanks for the help I may drop a size on the front.
Old Mar 17, 2015 | 07:45 AM
pmathews's Avatar
I'm running 235/60 x 15 on the front of my '67, and they are too small. I'll be trying 245s next time or maybe a 70 series that's taller.
Old Mar 17, 2015 | 12:46 PM
Sea five's Avatar
What size are you running on the rear. looks like they fill the wheel well.
Old Mar 17, 2015 | 04:23 PM
pmathews's Avatar
I'm running 275/60 x 15 in the back, and they fit great. In my '67, I could probably go even larger on the back, there's plenty of room in the rear. My 275s are 28" tall, and they never scrub.
I believe Eric is running a taller tire in the front, that might be an option (vs. wider). The 235s don't fill the wheel well in my car, but if they were a 70 ratio (vs. the 60), it would look nicer. I believe Eric is running a taller tire. The 235/60s are about 26" tall. 235/70s are 28" tall, 225/70s are 27" tall (approximately).
Old Mar 17, 2015 | 05:26 PM
I run a 225-70-15 in the front but mine is lifted. They rubbed with a stock, original, maybe worn springs.
Old Mar 19, 2015 | 08:10 AM
Sea five's Avatar
Thank you all. As always a lot of good info.
Tomorrow is spring w should be driving very soon !!!
Old May 19, 2015 | 09:11 PM
604Cutlass's Avatar
What sizes did you end up getting? I've got a 66' convertible that I'm trying to figure out the best size to get. Would like to improve the stance of the car and fill out the wells a bit.
Old May 20, 2015 | 08:53 AM
Sea five's Avatar
On the rear I used 15x8"wheels with 255/60 tires and on the front I used 15x7"wheels with 235/60 tires.
Old May 20, 2015 | 10:22 AM
This is completely useless without pictures...
Old May 20, 2015 | 12:59 PM
steverw's Avatar
Beautiful car man, great job! Where did you end up buying your wheels from? Thats my next big expense, tires and wheels. I do want the biggest tire i can safely stuff in the rear.
Steve
Old May 20, 2015 | 02:07 PM
604Cutlass's Avatar
Would love to see some pics if you've got them. I was thinking about 255/60/15 all the way around like you or 245/60/15 in the fronts. Would like to see how your combo looks.
Old May 20, 2015 | 02:31 PM
Sea five's Avatar
Did someone ask for pictures? Pictures it is
Old May 20, 2015 | 02:34 PM
Sea five's Avatar
More pics
Old May 20, 2015 | 02:38 PM
Sea five's Avatar
more
Old May 20, 2015 | 04:05 PM
Looks great. The redlines are awesome with those wheels.
Old May 21, 2015 | 06:13 AM
Sea five's Avatar
Wheels are from Summit Wheels Vintiques and tires are T/A from Dimondback
denf221
Wheels and Tires
Jun 21, 2012 08:30 AM
CutlassLegend
Sep 24, 2011 04:41 AM
Gary's 2 442-S
Wheels and Tires
Jan 4, 2011 03:08 PM
69442
Apr 9, 2009 06:48 AM
ragtop442
Jul 4, 2008 12:13 AM
