Click Here
15x8 with 4in backspacing
Old Sep 28, 2013 | 06:15 PM
72cuttys's Avatar
How will these wheels fit on a 71 Cutlass with stock wells? Was unable to find any helpful images or threads on chevelleforums or CO.
Old Sep 28, 2013 | 06:37 PM
Oldsmaniac's Avatar
It depends on how wide the tires are. I think a 5 inch backspace would be better in centering the wheel in the wheelwell. You could always measure or make a fake wheel of sorts with cardboard to check fit.
Old Sep 28, 2013 | 06:56 PM
72cuttys's Avatar
Is the 4" backspacing going to pull the wheel in? Or push it out? Sorry, im not too savvy when it comes to wheel measurements.
Old Sep 28, 2013 | 07:01 PM
Oldsmaniac's Avatar
The more backspacing on similar width wheels pushes the wheel inward so to speak. An 4 inch bs on a 8 inch rim puts the centerline in the middle. Little backspace creates a deep dish rim....
Old Sep 28, 2013 | 07:20 PM
72cuttys's Avatar
Thanks for the info. These were the tires i wanted to run.
http://www.summitracing.com/parts/bfg-16225/overview/
Do you think they will fit?
Old Sep 28, 2013 | 08:15 PM
gearheads78's Avatar
car guy
Really need a 10" wheel to look right in that tire. You need to measure on your own car but 10" with 5.5" BS is going to be close to what you need.
Old Sep 28, 2013 | 08:23 PM
72cuttys's Avatar
found plenty of people running a 295/50 on a 15x8 in this thread.
http://www.nastyz28.com/forum/showthread.php?t=193807
i am more concerned with the backspacing
Old Sep 29, 2013 | 09:50 AM
Actually, not quite. The wheel width is measured at the bead seating surfaces, inside-to-inside. Offset is relative to the width, so a zero offset would mean that the wheel mounting surface is centered.
Backspacing is measured from the inboard lip of the wheel to the wheel mounting surface. There is usually 1/4" to 1/2" of lip outboard of the wheel mounting surface. An 8" wheel with zero offset would have a backspacing of between 4.25" to 4.5", depending on the thickness of the lip.
doc
Dec 28, 2017 10:06 AM
Fastback71
Wheels and Tires
Jul 15, 2011 06:57 AM
toro68
Mar 28, 2009 01:36 PM
Toro68
Sep 28, 2008 04:48 PM
