Click Here
Wheels and tires finally installed
Old Oct 28, 2013 | 02:21 PM
tmaleck's Avatar
I got the wheels and tires mounted over the weekend. The wheels and tires that came on the car were OK, (235/70R14) but I felt they were more like Corvette or Chevelle Rally wheels than what a muscle car should have.
I ended up with Cragar 610P Vintage series wheels. One piece polished aluminum, so light weight and no rusting. I went with 15x7 front (+6mm offset) and 15x8 rear (0mm offset). I got Cooper Cobra tires, 215/70R15 front and 255/60R15 rear. They come close the the original 27 inch height and I had set up the speedo gearing and everything else based on that diameter. Given the rear suspension height, maybe a 275/60R15 would have filled the wheel well better, but the gearing was already installed, so It is what it is. Overall I'm very happy with the results.
Tim
Old Oct 28, 2013 | 03:00 PM
RetroRanger's Avatar
72 Olds CS
the rims and tires look really nice. Your car does sit up a little in the back. What do you have for springs inthe rear ? maybe cut a coil or get shorter springs ?
Old Oct 28, 2013 | 03:32 PM
jag1886's Avatar
Wheels look great.
Old Oct 28, 2013 | 03:34 PM
Olds442redberet's Avatar
Very Cool!
Old Oct 28, 2013 | 03:50 PM
gearheads78's Avatar
car guy
Cut 1/2 coil in the back and it will be just right. Wheels look good.
Old Oct 28, 2013 | 04:09 PM
69ishHoliday's Avatar
Good choice, I've been trying to decide between Olds Rally wheels and Cragars. The cost is about the same to restore a set of Rally's as buying new Cragars. The Cragars look great on your car, nice wheels and a nice looking convertible too. - Steven
Old Oct 28, 2013 | 04:46 PM
I've got P275-60-15 on 15x8 wheels in the back and P225-70-15 on 15x6 in the front. Those springs will settle a bit also. In the front I put a heavy duty spring to raise mine a bit.
Old Oct 28, 2013 | 09:12 PM
RandyS's Avatar
Nah, just raise the front, it will look awsome!
Old Oct 29, 2013 | 04:49 AM
chadman's Avatar
Wheels look good. Would look much better if you drop the back some.
Old Oct 29, 2013 | 05:11 AM
car guy
Only if he puts more tire in the back. Too much gap like it is.
Old Oct 29, 2013 | 06:53 AM
TK-65's Avatar
Turn white letters in.
Old Oct 29, 2013 | 07:53 AM
Sircajun's Avatar
KEEP the white letters out, but clean the mounting paste of them. Lower the back a bit and you´re there.
Old Oct 29, 2013 | 10:01 AM
tmaleck's Avatar
I kind of swagged the springs. I'm hoping they settle some, they are only a few weeks old. If not, I'll try a shorter set, may variable rate HD springs. They are not that expensive and easy to change, so I figured the Vista Cruiser springs were a good starting point. These springs are tapered on both ends, so I can't cut a coil. :-(
Thanks for the comments and feedback.
Tim
jnaarnold
Sep 12, 2017 08:09 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
67Olds442X2
Wheels and Tires
15
Apr 17, 2012 05:24 PM
ddx77
Jan 2, 2012 06:56 PM
Charlie_brown
Feb 11, 2010 01:13 PM
