Wheels and tires finally installed
I got the wheels and tires mounted over the weekend. The wheels and tires that came on the car were OK, (235/70R14) but I felt they were more like Corvette or Chevelle Rally wheels than what a muscle car should have.
I ended up with Cragar 610P Vintage series wheels. One piece polished aluminum, so light weight and no rusting. I went with 15x7 front (+6mm offset) and 15x8 rear (0mm offset). I got Cooper Cobra tires, 215/70R15 front and 255/60R15 rear. They come close the the original 27 inch height and I had set up the speedo gearing and everything else based on that diameter. Given the rear suspension height, maybe a 275/60R15 would have filled the wheel well better, but the gearing was already installed, so It is what it is. Overall I'm very happy with the results.
Tim
Tim
Good choice, I've been trying to decide between Olds Rally wheels and Cragars. The cost is about the same to restore a set of Rally's as buying new Cragars. The Cragars look great on your car, nice wheels and a nice looking convertible too. - Steven
I kind of swagged the springs. I'm hoping they settle some, they are only a few weeks old. If not, I'll try a shorter set, may variable rate HD springs. They are not that expensive and easy to change, so I figured the Vista Cruiser springs were a good starting point. These springs are tapered on both ends, so I can't cut a coil. :-(
Thanks for the comments and feedback.
Tim
Tim
