white walls
I was going to direct you to Westleys Bleach White. But it seems they have sold out to Black magic. Reports say its not even close to the original. So I dont knwo what to tell you. Wander the car care section and look for white wall cleaner. Report back if you find one that works. Google Westleys Bleach white. See for your self.
I used Westley's for years. I still have a good supply. However there does seem to be some controversy on the possible damage to whitewalls. I now use Simple Green and a stiff bristle brush. It works very well. I do not ever let my tires get really dirty. Coker Tire has several products to clean whitewalls but I have not tried them.
I use Black Magic all the time and find it superior to anything I have used in the past, Works just like the old Westleys and they say no damage to the tires or white walls, I'm on my third set of white walls and I see no problems so far.....Tedd
As sacrilegious as it might sound, I've always cleaned whitewall with a Brillo or SOS soap pad. Yes, I know it's steel wool, but I use it gently, and I've never worn off or marred the whitewall. Just one or two swipes is enough to get the dirt loose, and then I rinse it with a hose. It takes very little effort. I've been doing this on every car I've ever owned or otherwise had reason to wash going back to the 1970s, when I was washing my father's cars and when it seemed every car had narrow whitewall tires.
I agree with Tedd,I used Westley's for years, and continue to use Black Magic with no noticeable difference.For badly yellowed tires don't be afraid to use a brass brush or very stiff bristle brush. Larry
And still works... just more work than Bleche-Wite or other chemical cleaner.
Purple cleaner will clean whitewalls too among other things, just don't use it full strength near paint. Combined with a stiff plastic or brass bristle brush,it will clean them well and you can get it in 5-gal jugs.
Last set of W/W tires I bought for the wagon, last fall, that blue was the toughest I'd ever tried to get off. Chinese made tires. Took Bleche-Wite, brass brush and a lot of scrubbing to get it off. 'Course now, a shot of cleaner and a couple passes with pressure washer leaves 'em nice and white...
I bought a set of Toyo whitewalls a year or so ago for my pick-up 72 truck. Very, very limited selection for white strip tires, unless you want wide ones. The blue was very difficult to remove, and it took several attempts with an SOS pad to get it off. That said, the Toyo's ride and track very smooth. A friend of mine high up in the tire industry (not a tire changer) said the Toyo has a very good reputation in the industry. So far I like them a lot.
scothbrite pads work for me with a little detergent. Do not use on Diamond Back whitewalls magic erasers pads also work and allowed on Diamondback tires. A nail scrub brush works well for me. Been cleaning white wall more than fifty years still like them http://www.mcmaster.com/#7247T3
