Click Here
Larger than 315 rear tires 70-72 Cutlass S?
Old Nov 8, 2023 | 11:50 AM
JJ 86's Avatar
Has anyone successfully mounting anything larger than 315's on the rear of their 70-72 Cutlass S? I would love to run 345-25-20 or 345-30-19 on the rear. I'm curious if many have done so.
Old Nov 8, 2023 | 11:51 AM
fleming442's Avatar
Mini tub it
Old Nov 8, 2023 | 02:50 PM
wills30's Avatar
315
315 fit tire with a mickey. But these are on a 68
Old Nov 8, 2023 | 03:34 PM
Rallye469's Avatar
You’re trying to run incredibly wide low profile tires on a tall wheel?
you’ll have to figure that with a wheel figment tool.
https://www.speedwaymotors.com/Wheel...SABEgJExfD_BwE
Most of the guys here fit big tires for racing.
325 50/R15 are the biggest I’ve fit.
Old Nov 8, 2023 | 04:57 PM
JJ 86's Avatar
Did you have to mini tub to fit that tire?
Old Nov 9, 2023 | 03:41 AM
Rallye469's Avatar
Nope. Just the exact amount of back spacing on the wheel ….which for these tires is 5.5”
I imagine if the tire didn’t have such a big sidewall, you MIGHT be able to go with 6” BS?
Old Nov 9, 2023 | 09:56 AM
71 OLDS's Avatar
We tried with a 345 on my 71 442 and it literally goes from the frame rail to the lip. With a 12" wheel a 345 is 13.8" to 14.1" wide. The measurement from frame rail to the lip on my 442 was about 13.7". And that's with the lip rolled. You would either have to notch the frame to the inside or bulge out the quarters/do flares. As mentioned by others 325 (13" to 13.2") is the max you can go w/o major mods and it has to be centered/backspaced perfectly for the 325 to work. Here's a pic of a 345 touching on both sides.
-Joe
Old Nov 10, 2023 | 07:57 PM
JJ 86's Avatar
-Joe
Thanks for posting. That's the information that i was looking for. What size tire and wheel did you end up using?
Old Nov 11, 2023 | 12:10 AM
71 OLDS's Avatar
The car is in paint and body jail with lots of custom projects being done. It currently has 305/40/18s on the rear and 265/40/18s on the front but I did purchase my autocross wheels and tires. For the rear it's 11.5" wheels w/325/30/19s and on the front it's 11" wheels with 315/30/18s. The rears won't need any mods but lots of work will need to be done to get the 315s to turn lock to lock on the front. Here's a few pics with the 305/265:
Here's a pic of the new 19x11.5 rear wheel w/o the rocket sticker. Hope to have some pics with the new wheels/tires mounted in the next few weeks since all the front fender mods will be starting soon.
firefighter5174
Sep 21, 2014 10:33 AM
1001coins
Sep 2, 2014 03:40 PM
Vader
Oct 16, 2012 03:24 PM
ddd777
Sep 6, 2012 06:32 AM
ManCutty
Feb 27, 2012 06:49 PM
