Click Here
Code Stampings for 67 442 wheels
Old Nov 23, 2023 | 10:45 PM
1967442's Avatar
Does someone have a list (chart) of stampings for all the oem 1967 Olds 442 both drum and disc steel wheels.
I am adding disc brakes to a 442. All info will be appreciated. Thanks
Old Nov 24, 2023 | 12:50 AM
If you're adding factory discs from 67-72, either 4 piston or 1 piston, you can use the 67 HB wheels that were made for it, or you can use certain 1969 all chrome 14x6 SSIs, or all SSIIs, or any 14x6 SSI with trim ring, or certain 1971 SSI 14x7s.
If you're adding aftermarket discs, you'll probably need aftermarket wheels.
Old Nov 24, 2023 | 04:23 AM
1967442's Avatar
I don't guess I have ever seen HB wheels. I have wheels from a 1980's Chevy s-10 on it.
hurst68olds
Aug 16, 2020 01:27 PM
70vista
Sep 12, 2019 09:58 PM
wj67442
May 1, 2015 04:46 PM
Kid Thunder
Mar 21, 2015 03:49 PM
jimigisme
Brakes/Hydraulic Systems
Feb 8, 2014 05:49 AM
