Click Here
Vibration Comes and Goes
Old Aug 30, 2022 | 03:40 PM
Cossack's Avatar
66 cutlass
I've got a vibration on my 72 Supreme that comes and goes at around 60-65. It lasts a few seconds and goes away a few seconds. Not in the steering wheel but the whole car. I just had the rear u-joint replaced but I also put the wheels - which I had balanced last year with new tires - off my 66 on it at the same time. I didn't drive it on the highway until about a week after the change and that's when I noticed it. I'm thinking the rear wheels weren't balanced correctly or the u-joint is defective. Any thoughts?
Old Aug 30, 2022 | 03:48 PM
It could be any of a number of things. You're just going to have to troubleshoot until you find it.
Old Aug 30, 2022 | 03:56 PM
v8al's Avatar
Registered Olds Owner
Is the rear u-joint correctly seated in the pinion flange?
I replaced a u-joint in a 72 and had to slightly squish the ends of the u-joint with a c-clamp to get the u-joint to correctly seat in the flange.
Try jacking the car up and grab the rear (and front) of the drive shaft and try to shake it. If there's any play at all that needs to be addressed.
Old Aug 30, 2022 | 04:22 PM
Sugar Bear's Avatar
If light throttle pressure can vary it, look at the u-joint for binding/stickiness.
Good luck!!!
Old Aug 30, 2022 | 06:21 PM
Mr Nick's Avatar
Is the car lowered? Stock rear control arms?
Old Aug 30, 2022 | 07:53 PM
Cossack's Avatar
66 cutlass
It's not lowered and the rear control arms are stock. Going to double check the new u-joint tomorrow.
Old Aug 31, 2022 | 01:50 PM
Cossack's Avatar
66 cutlass
So I had the wheels balanced today and the culprit seems to be a slightly bent back rim. The guy who mounted them last year didn't catch it. Now I have to go to my rim pile and clean and paint another rim. At least I know what the problem is.
Old Aug 31, 2022 | 02:36 PM
Sugar Bear's Avatar
Good news.
Dusty72
Wheels and Tires
Aug 6, 2022 04:14 AM
mrteeser69
Jun 11, 2014 07:50 PM
travisbeamon
Wheels and Tires
Apr 22, 2012 05:49 AM
Tucker442
Alero
Sep 5, 2011 02:27 PM
