Alero Mag Wheels
Old Sep 3, 2011 | 11:46 AM
Tucker442's Avatar
Unhappy Alero Mag Wheels
I bought my son an 02 Alero in 04, what a pain the wheels have been, anytime I install tires and balance them with mag wheel or regular weights the tires leak at the weight, I have put 3 sets of tires on this car and they all do the same thing now the only way I can balance them is to use the stick on weights on the inside of the wheel, does anybody else have this same problem or is it just me.Silver Wheels not chrome not steel
Old Sep 3, 2011 | 04:05 PM
Redog's Avatar
No I never had this probelm with the stock wheels.
The only time I had a problem with the wheels was when I hit a pothole and cracked one of the wheels. That was back in 2001 and it became a problem in 2003, so I fixed the probelm by buying a new set of wheels.
$550 for new wheels or $405 for one wheel from the dealership. I think you know why I made that choice
I have a pair of 6 spoke gray wheels I used to use for racing only. No problems with them either
Old Sep 3, 2011 | 04:28 PM
Tucker442's Avatar
I remember a tech letter when working at the Olds dealer that those wheels would make noise at slow speeds they told us to break down the wheel, put talcum or baby power between the rubber and the rim then reinflate them, if we didn't move the tire on the rim we didn't have to rebalance them but they would make this silly rubbing noise at slow speeds like in a parking lot if you had the windows open you could hear it. I had a pot hole wheel issue also found a used wheel on eBay for 100 with the center cap
Old Sep 3, 2011 | 05:03 PM
Redog's Avatar
I never heard anything like that.
That "rubbing" noise would be "bad hub" related, I would think since I've heard of a lot of people having hub problems on newer GM cars and trucks
Besides, Talcum powder rots rubber quickly.
Old Sep 3, 2011 | 05:10 PM
Tucker442's Avatar
Well someone should told Oldsmobile that, it was with one of the suspension options with the goodyear tires only I think the size was 225 50 16
Old Sep 5, 2011 | 07:09 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Take the tires off and wire wheel the bead seat area on the rims. If they're leaking they're most likely corroded and rough in that area. All of mine (2001 16" aluminum) leaked slowly until I did that. Using the stick-on weights is fine, that's the way new cars come from the factory now. The bigger diameter wheels are often "flangeless" meaning they're smooth on the rim edge and can't take a traditional clip-on balance weight.
Old Sep 5, 2011 | 07:24 AM
Tucker442's Avatar
Hi Copper, I do that every time I replace the tires, have had issues over the years with all kind of wheels that get built up rubber on it causing a leak
Old Sep 5, 2011 | 08:05 AM
Lady72nRob71's Avatar
I was told by the tire shop that alloy wheels over 12 years old will corrode around the bead seal area and need either sanding or extra sealant. My caddy has that problem now and the extra sealer on the bead helps. They said mercedes has a big issue with this.
Not sure if this is your prob, but somrthing to think about.
Old Sep 5, 2011 | 02:27 PM
Redog's Avatar
That's the size of the top of the line Alero. I had those tires, BTW the GoodYears from the factory sucked. Wore out in less than 20,000 miles
virtualwsp
Jul 18, 2013 07:01 PM
alek72us
Jun 25, 2012 09:42 AM
1968Cutlassfallbrook
Wheels and Tires
Oct 9, 2011 09:47 AM
BIGJERR
Aug 9, 2011 05:40 PM
BIGJERR
Dec 17, 2009 07:46 PM
