Click Here
Oem tire size
Old Nov 6, 2024 | 09:23 AM
79cut's Avatar
Oem tire size
Anyone know what the oem tire sizes were for 1979 Oldsmobile cutlass ?
Old Nov 8, 2024 | 06:07 PM
69CSHC's Avatar
195/75 R 14
They are relatively small tires. On the short side and narrow.
The pics below are factory correct tire spec.
https://bringatrailer.com/listing/19...***-calais-12/
"Super Stock III 14″ wheels wear bright trim rings and are wrapped in older 195/75 Goodyear Aquatred II narrow-whitewall tires."
Old Nov 8, 2024 | 06:16 PM
79cut's Avatar
Originally Posted by 69CSHC
195/75 R 14
thanks. I was trying to compare tire heights
the previous owner put bigger brakes and had to up size the rims to 16 inch to fit
I’m debating on keeping brakes and getting new rims but 14-15 inch rims are in plenty supply way more choices than 16 inch
I prefer the rally style 14-15 inch type rims
I do like having big braking power but
Old Nov 10, 2024 | 05:11 AM
BlueCalais79's Avatar
x2 on the 195/75R/14, and optional was 205/75R/14. It is easier to find the 205's, currently HanKook has a decent whitewall this size and Coker just came out with 205 whitewall wherein the width of the ww is wider than the HanKook tire.
Old Nov 10, 2024 | 07:05 AM
205/75-14 tires are 26.11" outside diameter and 8.07" section width. 215/60-16 tires would be nearly the same OD at 26.16" and slightly wider at 8.46" section width.
Old Nov 10, 2024 | 07:17 AM
Don't forget that you can always go to Diamondback if you're looking for a white wall.
https://dbtires.com/
You can also get 215/60R16s in the Ironman RB12.
https://www.ironmantires.com/tire-details/Ironman/RB-12
I put these on my 96 98 and they looked great. Although I've heard that the new RB12s have problems with the rubber chemistry and the white walls turn yellow/brown. Mine never changed color.
https://classicoldsmobile.com/forums...-after-159937/
Old Nov 10, 2024 | 03:55 PM
79cut's Avatar
thank you
charlesg3425
Wheels and Tires
Nov 7, 2023 05:46 PM
Fitti Six
Wheels and Tires
Jul 26, 2013 04:38 PM
442b
Wheels and Tires
Jun 24, 2011 07:02 AM
snowballs442
Wheels and Tires
Apr 28, 2011 02:26 PM
