Click Here
Wheel recommendations for 1978 98
Old Jul 23, 2025 | 09:00 AM
illumined's Avatar
1978 Ninety Eight
I went to the tire shop for a rebalance yesterday and while that was accomplished successfully I was informed the lug nut holes are worn out and it's "losing contact on the back". He showed me what he was talking about, and I could see it very well. So, time for some new wheels, but naturally they didn't have any in their catalogue. I was given a couple of numbers here, 5x5 15 and 5x127 15. The wheels on there now are the originals most likely, as this is a driving car I'm going to need something soon to keep putting lots of miles on it. I looked at Classic Industries but I'm not sure if what they have will work, does anyone have suggestions for where I can find what I'm needing? Thanks.
Old Jul 23, 2025 | 09:29 AM
Tri-Carb's Avatar
Advertise under parts wanted for a replacement stock wheel.
Old Jul 23, 2025 | 09:56 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Originally Posted by illumined
I went to the tire shop for a rebalance yesterday and while that was accomplished successfully I was informed the lug nut holes are worn out and it's "losing contact on the back". He showed me what he was talking about, and I could see it very well. So, time for some new wheels, but naturally they (Who are they?) didn't have any in their catalogue (What catalog?). I was given a couple of numbers here, 5x5 15 and 5x127 15. The wheels on there now are the originals most likely (Steel wheel with a hubcap?), as this is a driving car I'm going to need something soon to keep putting lots of miles on it. I looked at Classic Industries but I'm not sure if what they have will work, does anyone have suggestions for where I can find what I'm needing? Thanks.
Are you in the USA?
5x5 is correct for the bolt pattern for the big cars
https://www.finishlinewheels.com/pro...84-s-00937-sil
Old Jul 23, 2025 | 12:31 PM
illumined's Avatar
1978 Ninety Eight
Are you in the USA?
They would be my local Les Schwab, where I got the tires from. Their catalogue would be their inventory. They keep an inventory of tires and wheels in addition to providing tire related services. That would be a stock steel wheel with a hub cap, although the hub caps were missing when I got it and I haven't gotten around to getting replacements. I'll check out the link, thanks.
Old Jul 23, 2025 | 12:52 PM
Did you take a picture? I find it hard to believe that OE steel wheels would get dangerously worn. Not unless your Oldsmobile has 500k+ miles on it. I doubt even @joe_padavano has an Oldsmobile with that many miles.
Old Jul 23, 2025 | 01:58 PM
illumined's Avatar
1978 Ninety Eight
Normally yeah but with an unknown maintenance history anything is possible. It was on the road for 20 years before it was first parked.
Old Jul 23, 2025 | 02:05 PM
CutlassMarc's Avatar
Ya, that seems odd. Maybe a p/o drove it with loose lugnuts and caused te wear. In that case it would be only one wheel. I'd hope,
Old Jul 23, 2025 | 03:13 PM
Or it could have the wrong lug nuts?
Ya snap a pic of the WOW lug holes. (worst of the worst).
Be advised if you buy new make sure they are NOT off shore.
Other GM big cars used this same rim. Widen your search, it may produce.
https://www.ebay.com/sch/i.html?_nkw...441.m570.l1313
Old Jul 23, 2025 | 07:23 PM
The stock wheels on that 1978 Olds 98 were 15" diameter, 6" wide, and have a 5 x 5" bolt circle. For the math-challenged, 127mm is exactly equal to 5", so 5x5" and 5x127mm are the same bolt pattern. It is certainly POSSIBLE for the lug nut holes to become worn if the car is driven for a long period of time with the lugnuts incorrectly torqued. These particular wheels were used on 1977-1984 Oldsmobile 98s and Buick Electra 225s. They are surprisingly difficult to find used, as most of those cars have long ago been scrapped after being used for demolition derbies. The B-body station wagons used the same 5 x 5" bolt circle but came with 15x7 wheels.
Old Jul 24, 2025 | 11:29 AM
illumined's Avatar
1978 Ninety Eight
I looked at Finish Line Wheels, theoretically they have them so I emailed them to see what's in stock. In the meantime I found a wheel that's listed for a Chevy C10 that seems to be the right pattern and size. Think this could work?
https://www.cjponyparts.com/wheel-vi...0/p/WV62025-V/
rfpowerdude
Wheels and Tires
19
Apr 14, 2023 11:21 AM
drjaredshelton
Ninety-Eight
16
Feb 22, 2021 05:02 AM
Old Rocketman 98
Wheels and Tires
Oct 17, 2019 08:43 AM
Edward Taylor
Wheels and Tires
15
Feb 17, 2017 01:45 PM
wjustinmartin
Ninety-Eight
Feb 11, 2010 07:38 PM
