Click Here
70 442 tire fit? 16x9.5, 4.5 backspace
Old Dec 29, 2023 | 08:51 AM
Don M's Avatar
Hello, I have a 1970 442. Have an opportunity to buy 295/50r16 on a 16x9.5 rim with 4.5 back space. Do you think they will fit? The back space has me concerned.
Old Dec 29, 2023 | 11:44 AM
70sgeek's Avatar
'72 Cutlass ragtop
That sounds like a potentially tight fit if you have a stock-height rear suspension (and that assumes it's not sagging from aged springs). May sit too close to your inner wheel well lips at that width / backspace combo.
Best idea might be if they're local to you is to test fit before you buy
I run 17x8's with 4.5" BS all around on my CS stock-height suspension, the rear has 1" spacers for an effective 9" track. But my tire size all around is 245-50-R17, which clear the rear wheel wells without issue - but you might be coming significantly closer (if not practically touching) to yours with the combo you're suggesting.
Old Dec 30, 2023 | 02:43 AM
4.5" backspace on a 9.5" rim width is not zero offset and will push the tire outboard, likely rubbing on the pinchweld flange at the wheel opening.
Old Jan 12, 2024 | 05:36 PM
Don M's Avatar
Thanks for the replies. I decided not to go with these rims. finding a 16 inch tire isn't the easiest...
jopa
Wheels and Tires
Nov 19, 2022 06:14 AM
mcgeekgirl
Wheels and Tires
Jun 27, 2020 10:11 AM
2oldsguy
Wheels and Tires
Jul 26, 2018 07:01 AM
NotDads442
Wheels and Tires
Apr 16, 2018 09:40 PM
olds 307 and 403
Wheels and Tires
15
Dec 10, 2017 06:50 AM
