Click Here
Rim question for my 79 cutlass
Old Sep 18, 2024 | 08:15 AM
79cut's Avatar
I just purchased a 79 cutlass but has 2000 Camaro brake calipers on the front
the tires are 225 55 16 but they rub on the brake line holder
I’ll probably go with a 195 55 16 tire
my question is did they make oem rims for the g body in 16 inch ?
all my research shows 14-15 inch
eventually I would like a oem rim but it has to be 16 inch
Old Sep 18, 2024 | 01:55 PM
Your research is correct. The 16” wheels currently on the car may not have the correct backspacing.
Old Sep 18, 2024 | 06:06 PM
69CSHC's Avatar
As far as I know the only G-Body that came with 16 inch rims was the GNX.
If I recall correctly late 1980s Pontiac GTA rims will fit, but only the fronts. So you will need 4 fronts on a G-Body Cutlass.
P.S. you will need further verification for sure as you own a A/G.
Old Sep 18, 2024 | 06:44 PM
79cut's Avatar
Thanks for the tip
outrightolds
Wheels and Tires
22
Jun 20, 2022 10:15 PM
1966 Cutlass
Wheels and Tires
Dec 3, 2020 03:23 AM
Bigmarvt13
Wheels and Tires
Dec 7, 2019 08:34 AM
Sid
Jul 15, 2016 06:43 PM
audiodox
Feb 13, 2009 01:22 PM
