Click Here
SS IIs and SS IIIs
Old Dec 26, 2023 | 11:54 AM
72455's Avatar
1972 U code Supreme
SS IIs and SS IIIs
What's the difference?
Old Dec 26, 2023 | 12:58 PM
4speed455's Avatar
Color. SSII are argent grey and SSIII are the lower body color.
Old Dec 26, 2023 | 01:17 PM
72455's Avatar
1972 U code Supreme
So other than that, no difference?
Old Dec 26, 2023 | 01:30 PM
allyolds68's Avatar
There are so many threads on this subject......
Here is just one:
https://classicoldsmobile.com/forums...-based-167177/
and another:
https://classicoldsmobile.com/forums...wheels-114256/
and another:
https://classicoldsmobile.com/forums...s-ssiii-61438/
And I used your own words to search (SSII SSIII difference)
Old Dec 26, 2023 | 05:45 PM
Depends upon the year. For example, the SSIII became a 15” wheel with snap-on center caps in 1975; prior to that it was a 14” with bolt-on center caps.
Old Dec 27, 2023 | 02:30 AM
As others have noted, RPO N66 SuperStock II wheels are argent, RPO N67 SuperStock III wheels are lower body color. Within a given year, that is the ONLY difference. For your 1972:
Old Dec 27, 2023 | 09:49 AM
As others have noted, RPO N66 SuperStock II wheels are argent, RPO N67 SuperStock III wheels are lower body color. Within a given year, that is the ONLY difference ...
Depends upon the year. For example, the SSIII became a 15” wheel with snap-on center caps in 1975; prior to that it was a 14” with bolt-on center caps ...
An apparent contradiction. Who's right?
Old Dec 27, 2023 | 10:01 AM
Read it again. There is no contradiction. WITHIN A GIVEN YEAR, the only difference is paint. That means that all SSII and SSIII wheels within ONE MODEL YEAR are the same stamping. Yeah, in 1974 you could get 14" and 15" versions, but again the only difference between SSII and SSIII was the paint. Also, the center disk is still the same stamping on 14" and 15" versions - only the rim is different.
Old Dec 27, 2023 | 10:39 AM
redoldsman's Avatar
Proud Viet Nam Veteran
How about clarification on the bolt on caps and snap in caps. I know that 14" came with both. My 75 Hurst has 15" with snap in caps but I think the 15's also came with bolt in caps.
Old Dec 27, 2023 | 11:37 AM
All 1974-older are bolt-in. All 1975-newer are snap in. Again, WITHIN a given year, the only difference is paint.
Feb 14, 2025 01:28 PM
jimvbills
Dec 28, 2024 09:59 AM
Jamesbo
Jan 15, 2013 05:50 AM
TrackDay
Nov 9, 2012 04:48 AM
72 Supreme
Oct 29, 2010 12:51 PM
