Click Here
wheel offset nightmare
Old May 12, 2023 | 08:36 AM
philv1983's Avatar
So I've been researching for at least a week now on the correct backspacing and offset I need for my 72 cutlass. I have a custom direct bolt in ford 9" coming soon and its narrowed 1" on both sides. I can't leave it on stands for weeks waiting on wheels, so I'm trying to order wheels asap. car is getting that axle, BMR !' drop suspension, and I'm thinking 18x8 in front and 18x10 in rear. If i can find all the info from someone running 10" rears on stock diff, then I could just do the math for correct spacing with my narrowed rear.
Old May 12, 2023 | 01:40 PM
IndianaOlds1971's Avatar
I had 15x10 with 5.5" back spacing and 295-60 tires, they would slightly rub when you took a corner too fast and the body rolled.
Old May 12, 2023 | 06:27 PM
The experience of other people will be meaningless to you unless their axle flange-to-flange width is exactly the same as yours. Since yours is narrowed from the stock width, that will obviously change the necessary backspacing.
Old May 12, 2023 | 06:30 PM
philv1983's Avatar
but if I can find out what others are running with a stick 8.2 10 bolt, then I can just do the math for mine since its just 1" shorter on both sides. Thats why im going with 10" wide. Gives me a little wiggle room.
Old May 12, 2023 | 06:44 PM
Understand, but you might want to ask them exactly what axle they are running, since widths can vary.
Old Jun 11, 2023 | 07:46 AM
Bubba68CS's Avatar
There's a table in this article that lists some options to get you in the ballpark. I will eventually be going to a larger wheel (diameter and width), but will be measuring mine before ordering. I would hate to spend money on wheels only to find out something about my particular car doesn't work like others. They are a half-century old at this point...
https://www.motortrend.com/how-to/pi...arly-chevelle/
Old Jun 11, 2023 | 02:13 PM
dc2x4drvr's Avatar
Here is how I checked offset.
https://www.speedwaymotors.com/Wheel...up,485869.html
Old Jun 11, 2023 | 03:15 PM
cdrod's Avatar
Rodney
Rear Wheel Clearance: 18x9, 5.25" Backspacing
Here's some rear wheel clearance pics from my project with the following specs:
Differential - Stock rear end (not narrowed)
Wheel - 18x9 +8mm offset, 5.25" BS
Tire - 285/40R18
The clearance to the frame is about 1.5" (there will be less clearance to the inner wheelhouse)
Rodney
285/40R18 tire on an 18x9 wheel with +8mm offset.
Approximately 1.5" clearance to the frame.
This is my outer clearance. This was during quarter panel replacement and the new quarter is not fully welded, only clamped with vise grips.
The rear wheels are recessed a bit even though I squeezed a 285 tire in the stock wheel wells. I could have chosen a wider wheel or a smaller backspacing.
Old Aug 11, 2023 | 02:09 PM
philv1983's Avatar
So I've decided not to do the new axle at this time, but still have the itch for new shoes for her. Only problem is finding wheels with the correct BS to make it look right without rubbing. What BS are you guys running with a 10" wide rear and 8" wide front? Looking to get 17's, but speedway is showing me 4" BS when I've read other guys running 5". All stock 8.2 drum axle, disc in front. Plan on lowering the car 1" all around.
Old Aug 11, 2023 | 02:21 PM
fleming442's Avatar
I have a 275/60-15 on a 10" with 5.5 backspace. You don't need offset; that's import crap.
That's about ride height. Jackstands are on the axle tubes
Old Aug 11, 2023 | 03:25 PM
cdrod's Avatar
Rodney
The 18x9 Bandit offset is equal to 5.31” backspace. On my ‘72 Cutlass/442 I have at least 1-1/2” clearance to the frame rail on the inside and could easily push out at the fender lip another 1/2-3/4” without moding the fender lips. I think an 18x10 with 5-1/2” or 5-3/4” back space would fit and fill the fender wells.
Old Aug 11, 2023 | 07:39 PM
70sgeek's Avatar
'72 Cutlass ragtop
on my '72 ragtop I'm running 17x8 American Racing wheels all around - 4.5" BS but with a 1" spacer on the rear wheels to stagger those out a bit. I opted for that to allow for 4 wheel tire rotations. I run 245-50-R17 rubber all around.
no clearance issues on stock height springs front and rear.
Old Aug 11, 2023 | 08:48 PM
philv1983's Avatar
I think I have a couple of options. Going to discount tomorrow to make a decision. Is it just me or are the torque thrust 2 wheels kinda played out? I like them, but I like to be more unique.
Old Aug 12, 2023 | 01:52 AM
fleming442's Avatar
TT2s have been played tf out for about 10-15yrs. They only look really good on a few cars, but mf'ers think they have to be on EVERY car and truck!
Old Aug 12, 2023 | 12:51 PM
philv1983's Avatar
So I ordered wheels and tires. Not tt2's and should be here Thursday ready for pick up.
Old Aug 12, 2023 | 01:48 PM
cdrod's Avatar
Rodney
So, what was your final wheel configuration? Size, width & backspace??
Old Aug 12, 2023 | 01:57 PM
philv1983's Avatar
Originally Posted by cdrod
So, what was your final wheel configuration? Size, width & offset??
so I ordered 18x8 fronts 4.5 bs. Rear I ordered 18x10 0 offset whatever bs that comes to. I think 5". Rear tires are 295/35 fronts I believe are 245/40.
Old Aug 12, 2023 | 02:26 PM
cdrod's Avatar
Rodney
Phil:
10" rim with 0mm offset is 5.5" backspace. I look forward to seeing pics with the new rims.
Rodney
Old Aug 12, 2023 | 02:28 PM
philv1983's Avatar
Phil:
Rodney
ok I wasn't sure, but my guy said itll fit. Pics next weekend.
Old Aug 19, 2023 | 01:05 PM
philv1983's Avatar
such a big difference. 18x10 rears 18x8 fronts. Plus led headlights. Next is installing my 442 grills. Didn't realize how hard the grills are going to be.
Old Aug 19, 2023 | 05:20 PM
BackInTheGame's Avatar
Looks sharp! I don't usually go for the oversized rims, but yours are well-executed and look great.
Dusty72
Wheels and Tires
Aug 6, 2022 04:14 AM
speedaddict78
Wheels and Tires
Jan 16, 2013 09:27 AM
basssnake
Jan 16, 2011 12:26 PM
skubydobdo
Ninety-Eight
Aug 27, 2008 09:05 AM
ricardo
Drivetrain/Differentials
Mar 16, 2008 07:04 PM
