Click Here
Will 15x7 Cutlass rally wheels fit my '72 98
Old Aug 15, 2023 | 10:29 AM
jpilk99's Avatar
Hi All. I have regular steel wheels with hubcaps that came with my '72 98 and thinking of buying these "15x7 inch olds Cutlass rally wheels". Think they'd fit?
Old Aug 15, 2023 | 10:52 AM
66SportCoupe's Avatar
No bolt pattern is not the same. Wheels are 5 on 4.75. Your car is 5 on 5.
Old Aug 15, 2023 | 10:57 AM
jpilk99's Avatar
Thank you
Old Aug 15, 2023 | 11:25 AM
You need to find a set of SS IVs. They were the 5x5" bolt pattern wheels in 1972.
https://classicoldsmobile.com/forums...e-ssivs-73014/
Old Aug 16, 2023 | 05:51 PM
jpilk99's Avatar
I notice that these SS IVs don't look exactly like the Rally wheels; though they're certainly "sportier" than my steel wheels with pizza tray hub caps. I like a bit of a muscle car look, have raised the rear end of my 98 about 3" and put 275/60/15 RWLs all around.... Would love a set of wheels that look like the ones I attached above, Rally wheels like what went on Cutlass', to go on my car. Any ideas?
Old Aug 16, 2023 | 07:19 PM
rocketraider's Avatar
Oldsdruid
Unless you find a set of the SUPER-RARE 15x7 5x5 bolt circle SSIII that were made for the 1977 Delta 88 Pace Car, the only way a SSIII will fit a Ninety Eight is with an adapter. You'll have to be careful with fender skirt clearance using those.
Old Aug 17, 2023 | 03:13 AM
Just check out Summit or Jegs and find an aftermarket wheel you like. Currently, my 71 98 has Eagle Alloy 058 rims on it. I actually just bought a set of aluminum wheels off of a Chevy Caprice that I plan on refinishing and installing.
rr1964purple
Jun 27, 2016 07:23 PM
Jons
Jun 29, 2014 11:50 AM
72 cultass bronze rims
May 18, 2013 02:57 PM
rayfrausto
Sep 25, 2011 04:47 PM
