PDA
View Full Version : Electrical
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Hybrid 10SI/10DN alternator in 72
  2. Question about headlight prongs🤔
  3. 4 way flasher??
  4. 69 Cutlass horn contact
  5. Turn signal 70 442
  6. Question about external voltage regulator
  7. Starter wiring 1971 Cutlass
  8. Safety neutral switch bypass
  9. LED Halo head lites
  10. Help! possible grounding / no start
  11. 69 442 convertible power window installation
  12. Alternator on 68 cutlass
  13. Turn signal circuit PSA
  14. Help!! new generator and battery and still nothing
  15. Headlamp with DRL light
  16. Dead Short - Interior Lights
  17. 67 Olds A/C wiring again
  18. 72 coupe | power window | wire routing for doors
  19. 1969 Ninety-Eight courtesy light issues
  20. Battery tray location 72 Cutlass S/Supreme
  21. 67 C/S Voltage regulator ?Condenser?
  22. Need help with neutral safety switch..
  23. Non Rallye Pack to Rally Pack Conversion, are they telling me the truth?
  24. Looking for an 1157 LED
  25. 1974 cutlass wiring connector missing!
  26. 67 C/S AC wiring?
  27. 67 C/S dash circuit board ground?
  28. Tachometer wiring diagram
  29. Help! No power to a/c compressor!
  30. I Did Something Dumb -Triage help
  31. 67 C/S A/C car dash wiring
  32. Turn signal test 1969 442
  33. Ignition lock won't lock
  34. Distributor Woes
  35. High voltage on 67 Cutlass 442
  36. Help! 1966 Olds 98 Will Not Start
  37. Wiring Pertronix Ignitor on '56 Olds 88
  38. Horn ring/turn signal issue.
  39. engine compartment relay
  40. 69 Cutlass Convertible Stereo Upgrade Scope Creep
  41. Cigar Lighter Wiring
  42. 67 442 fuel gauge won’t drop
  43. '68 4-4-2 Ignition switch - Test it? Replace it?
  44. OE distributor?
  45. LED Dash replacement bulbs
  46. 1970 Cutlass starting issues
  47. Radio oldsmobile
  48. Another fuse panel question
  49. power window switch
  50. Need help with wiring 2 speed wiper motor
  51. Delco Battery Listings
  52. Heater fan motor works, car turned off
  53. 88 cutlass supreme no power
  54. 69 442 Voltage Regulator
  55. 1969 442 PWR Antenna Switch
  56. Radio Wiring
  57. Headlight switch knob removal? Help pls
  58. Rectangular Headlamps #4652
  59. 4 Speed Console tach question
  60. Battery troubles
  61. HVAC wiring
  62. Alternator Wiring Hook Up Question
  63. Tail light problems
  64. 67 C/S Power antenna
  65. after market power antenna
  66. MSD 8830 noise filter
  67. looking for a high torque starter
  68. 72 Cutlass High Blower fuse
  69. Wiper Wires ??
  70. Could this be it
  71. 1972 Cutlass AM/FM Radio
  72. 76 98 Thermal Limiter location
  73. Blower motor
  74. Replaced Delcotron and now have AMP light
  75. No low beam with high beams
  76. Please help me 1955 Oldsmobile Super 88
  77. Antenna Ground strap on 1971 Cutlass Supreme
  78. replacement battery
  79. Vista Cruiser tailgate window question
  80. Help with adding additional fuse box for Ignition, starter and other accessories
  81. 67 parking brake bulb #
  82. Spark plug wires
  83. Cheap brake switches?
  84. 1970 Cutlass fuel gauge issue
  85. Low voltage at the coil
  86. Stuck temp gauge Erratic amp gauge
  87. Internal reg Alternator | odd smell | 72 455
  88. Disabling the Beeper/Buzzer, 1980 Ninety-Eight
  89. '64-65 Bullet Tachometer Hookup (only 3 wires)
  90. Air conditioning. Fast idle solenoid
  91. Electrical connections under dash
  92. Horn wires
  93. Oil/ Temp sending units
  94. radio suggestion for 61 olds 88
  95. Orange Power Wire for the Tach
  96. What are these connections for?
  97. Voltage at coil
  98. Steering wheel/column horn wiring....
  99. Basic wiring issues - Rally Pac
  100. 82 cutlass supreme no start & hard brake
  101. 1970 neutral safety switch dual gate
  102. Dash cruise control switch on 71-72 Cutlass?
  103. Need Help with Temperature Sending Unit
  104. Windshield Washer Issue
  105. Start up problems on 68 442
  106. 1967 442 negative battery cable
  107. Rally Pac Tach Accuracy
  108. Weird Wiring
  109. Tachometer Shielded Ground Wire
  110. Key is “off” | car keeps running
  111. Temp sending unit
  112. Delta 88 '81 headlight switch
  113. Question heater blower motor switch 72 Cutty
  114. Fuel gauge problems
  115. Color wiring diagram for 1964 starfire
  116. Vac advance timing port
  117. Engine wire harness
  118. Restomod Coolant Switch/Sending Unit
  119. Which prong to connect radio to ignition switch 1950 98
  120. Car stereo
  121. 70 455 Supreme Rewire
  122. Replacing wiring harness
  123. Electric choke - voltage diagnosis
  124. Shocked myself.
  125. 1968 442 Holiday Coupe Marker Lights Not Working
  126. Question on 74-75 Rally Gauge wiring
  127. 1964 Cutlass 455 Hei install
  128. NEED HELP with wiring 6 PIN LED push button for ENGINE FAN
  129. No reverse or turn signals on my 66
  130. Under dash lamp short
  131. 68 442 Battery Tray install
  132. Engine Harness
  133. 69 cutlass convertible switch replacement
  134. 73-74 Hurst Olds digital tach
  135. tachometer for a 61
  136. Wiring diagram
  137. Gen light and power from alternator??
  138. Need help no spark
  139. frayed wire in engine harness
  140. Newbe 1964 Dynamic 88 2door hardtop built in Ont. Canada
  141. Interior lighting issues 1968 442
  142. Speedo Cable Lube- Seeking Assistance
  143. 1967 C/S engine harness plug
  144. Couple questions switching to 100 amp internally regulated alternator
  145. Olds' Cutlass Indicator light Out- Assistance Needed
  146. Do Battery Desulfators Work?
  147. 1968 442 accessory fuse port & tach harness question??
  148. Wiper switch identification
  149. radio and 8 track player repair and restoration
  150. A team performance 21 circuit universal harness
  151. 2-wire Park, Stop & Tail light sockets in ‘68
  152. door jamb switches 56 Olds
  153. 1990 Custom Cruiser Mystery Ground Strap
  154. A team performance 21 circuit harness block mount on 68 442
  155. Power window connections problem 1969 Cutlass
  156. Distributor Shimming
  157. U.S. vs European 1978 Delta 88 tail light wiring
  158. Power Window Issue- one window
  159. Washed out engine bay, car started I parked it next day won’t start
  160. Distributor Spring Pin
  161. 66 Cutlass turn signal help
  162. 1972 350 Starter Wiring Problem
  163. Alt/gen question
  164. Is this orange wire in trunk for trunk light?
  165. 1963 Dynamic 88 Heater & A/C Control Wiring
  166. No Power at starter/neutral safety switch
  167. Progression Ignition HEI
  168. Panel lights on 65 Olds 98
  169. Winter project, LED upgrades
  170. Windshield Wiper Systems
  171. Packard Electric Wiring Repair Manual
  172. Battery relocation 1966 Cutlass
  173. 71 442 grid rear defroster
  174. advise for HEI and alt upgrade on 67 CS
  175. 67 C/S Battery
  176. Clutch start switch help
  177. Need Assistance Finding Instrument Panel Lamp
  178. 1965-1969 4-Speed Console Curtesy Light
  179. Panel bulbs Re: 67
  180. 1966 Cutlass 330 battery cables.
  181. Cigar lighter not heating up
  182. 72 455 | new motor, mini starter | won’t engage starter
  183. Door Jam Switch Question
  184. MSD Ready to Run Wire Gauge
  185. 1969 cutlass gas gauge
  186. Headlights and buckets 72
  187. 12v source for gauges
  188. help pls!! car only starts when hot wired
  189. 1984 Oldsmobile Delta 88
  190. 65 olds f-85 backup extension
  191. Side Marker Lamp 194 bulb replacement Woes
  192. The GM park/turn tail light bulb socket woes
  193. 68 Cutlass ignition switch and key not cranking everytime
  194. 73 Delta88, accidentally hooked up battery backwards.
  195. Powermaster Alternator
  196. Night watch
  197. fuel gauge wiring diagram 1982 olds 88
  198. 1972 Cutlass Supreme Rear Window Defrost Grid trunk wiring
  199. Missing P/E brake switch
  200. Help identify this ground (and other wires)
  201. What's that... Cant see it on the wiring diagram
  202. 85 delta 88 VR location?
  203. Low spark, low voltage, no start
  204. Newb ignition coil question
  205. Cold AIR induction... Replace the headlights
  206. Ignition key lock cylinder
  207. 57 98 fuel gauge not working
  208. 1969 H/O alternator/reg electrical hook up
  209. BAT/IGN/ACC Slide terminals on 68 Cutlass fuse panel
  210. 70 olds 442 loosing 12v to ignition intermittently
  211. Led lights and flashers
  212. So far so good with dash clock...
  213. alternator whine into radio, gets worse with headlights
  214. And yet another electrical question 🤔 (ash tray light)
  215. Hot light Iluminates but car wont start even when cold
  216. Houston, we have a problem...
  217. Under dash lights 70-72 cutlass
  218. Electronic ignition recommendations
  219. HEI Module
  220. Rookie question about tach with clock...
  221. Winter light project
  222. Electrical issue after installing tach
  223. 84 Ninety Eight grounding, electrical, alternator troubleshooting
  224. '70 Cutlass/442 POWER WINDOW harness routing on floor
  225. Clock stopped working
  226. 1970 - 73 Oldsmobile Night Watch Option
  227. Alternator upgrade?
  228. 8 track player mechanical repair
  229. 69 front turn signal and back up sockets
  230. Greenhorn with multiple questions
  231. Transmission kickdown wiring issue
  232. Convertible Top Switch
  233. 68@118 Won't start
  234. Wiring help
  235. Reverse lights on a 49 Olds 88?
  236. 53 horn parts
  237. Extra connector?🤔🤔
  238. Dome Lights not working 1955 Olds
  239. 1964 Olds Cutlass 330 4v clock removal
  240. 1957 Super 88 What Cable Is This
  241. Need suggestions to fix buzzing sound
  242. Source for wiper motor '63 f-85
  243. Electrical terminals/connector bodies?
  244. electrical gremlins
  245. Modern fuse boxes with reproduction harnesses?
  246. Do I need some kind of reducer for the HEI distributor to tach?
  247. 2 starter solenoids on my 68 442?
  248. One Wire Chrome Alternator
  249. 67 Olds 98 Turn Signal Switch wilt-Telescope Wheel
  250. Brown/white charge warning lamp resistor wire?
