Replaced Delcotron and now have AMP light
Old May 17, 2021 | 04:30 AM
smparr's Avatar
I have a 1970 98LS and this weekend I replaced the alternator and voltage regulator and now I have a dim AMP light. The voltage regulator is another solid-state from Autozone. I already had one on it but the new one has the tall box like the original. The alternator is an AC Delco rebuilt original. I replaced an aftermarket Remy because it was howling at start-up and whirring but the AMP light was not lit before. The new alternator is a little noisier when running than the old one was before its shenanigans. Anyone had this problem? Also of note, every power drawing shows a ground on the alternator but the only thing I've ever had attached to the ground stud is a clip that supports the wiring harness. Should there be a black ground wire somewhere? Thanks for the help.
Old May 17, 2021 | 06:02 AM
The alternator grounds thru the alternator case to the mounting hardware. No external ground is needed.
The alternator warning light gets its ground thru the regulator. Since you say the alternator is noisy now, and the lamp is dim, I’d suspect a defective diode in your new alternator. If you have a voltmeter, set it to A/C voltage and measure across the battery posts. I don’t remember the specifications for A/C voltage, but I would think more than a few millivolts of A/C voltage would indicate a leaky diode in the rectifier bridge.
Old May 17, 2021 | 08:02 AM
smparr's Avatar
I'll try that tonight. I hope I didn't get a rebuild that's defective.
Old May 17, 2021 | 08:42 AM
rocketraider's Avatar
Oldsdruid
It wouldn't be the first time. Won't be the last time. 🙂
Did you have to turn in your original as a core? I like getting electrical stuff rebuilt by a local shop if possible. One, to support a local business (or forum member, there's a couple of highly competent rebuilders here) and two I just believe they'll do a better job.
Old May 17, 2021 | 09:02 AM
smparr's Avatar
I still have the howling one that didn't light the light and the other voltage regulator. I wanted to be sure everything worked before sending the core to RockAuto.
Old May 17, 2021 | 09:14 AM
smparr's Avatar
Would it hurt to attach external grounds to the alternator and voltage regulator on the odd chance that the case grounds aren't making sufficient contact through the cases/bolts?
Old May 17, 2021 | 09:16 AM
Oldsdruid
If there's no auto electric shop nearby, PM "Stellar" here on the forums. He's near Pittsburgh and has been doing auto electric for many years.
For the dinky core charge you'd get by sending it back to RA, invest in a professional quality rebuild.
Old May 17, 2021 | 09:27 AM
Yeah, but...
The stock Olds mounting bracket only attaches to the front frame of the alternator. That means that the ground path is from the aluminum rear frame, to the iron core of the stator windings, to the front frame. Galvanic corrosion between the aluminum and iron causes resistance in the ground path. This is less of a problem for the external regulator alternators, but the SI family, and especially the CS130, are really sensitive to this. A ground strap from the rear frame to the block is never a bad thing. Evil ex-wife #2 had a W-body Buick GS that would puke the CS130 about every 13 months (the warranty was 12 months). After the third time, I finally found the TSB that said to install the ground strap.
Old May 17, 2021 | 11:23 AM
smparr's Avatar
Not the alternator ground stud itself?
Old May 17, 2021 | 11:31 AM
I'm not sure what ground stud you're talking about, but any ground strap that makes electrical contact with the rear half of the alternator is fine.
Old May 17, 2021 | 11:38 AM
smparr's Avatar
The shop manual shows the two studs on the back as BATT and GRND and the two prong plug for the regulator is between them. Right now the only thing on GRND is a clip holding the harness up in the back.
Old May 17, 2021 | 11:41 AM
smparr's Avatar
Like this
File Type: docx
Old May 17, 2021 | 11:49 AM
Again, any point on the rear part of the alternator is electrically the same as far as a ground strap is concerned.
Old May 17, 2021 | 01:00 PM
There should be a star washer on one of the regulator mounting bolts to ensure good ground contact between the regulator housing and the firewall.
Old May 17, 2021 | 01:07 PM
Which doesn't help with the galvanic corrosion problem if the mounting brackets only bolt to the front half of the alternator.
Old May 17, 2021 | 01:56 PM
Put the old regulator back on and see if the light goes out. If it does then just change the covers. There has been a rash of faulty solid state regulators over the years.
Old May 17, 2021 | 02:06 PM
smparr's Avatar
There was not a star washer. I will try a ground strap. If that doesn't work, I'll go in reverse and put the old parts back in.
Old May 17, 2021 | 08:57 PM
Sugar Bear's Avatar
If the light goes out with the alternator unplugged it probably has a leaking diode in the rebuilt unit.
Good luck!!!
Old May 17, 2021 | 10:27 PM
smparr's Avatar
Turns out it was the alternator. It's on its way back to RockAuto as a Delco warranty exchange. I put the old VR back and the light actually got a little brighter but when I put the old alternator back it went out. Oddly enough the old one stopped howling.
Old May 18, 2021 | 06:47 PM
Engineers are not supposed to be superstitious. Or, maybe we are supposed to be overly suspicious. Never figured that out, but I have noticed the phenomenon of failing equipment straightening up and flying right after the replacement part arrives, and will often stay that way until you send the replacement back for refund, if you do.
Old May 18, 2021 | 06:50 PM
Well, hell, of COURSE that's true. The old car never ran better until you put it up for sale or buy a new one.
Old May 18, 2021 | 06:52 PM
I should add that this is a corollary to the fact that the quickest way to find that tool you lost is to buy a replacement. The old one usually materializes at your feet as soon as you press BUY on the webpage.
Old May 18, 2021 | 09:34 PM
Oldsdruid
Any malfunctioning component will work perfectly when demonstrated for the repairman.
Old May 19, 2021 | 07:24 AM
That’s because equipment/machinery/whatever enjoys making you look like your a liar!!!
Old May 19, 2021 | 07:26 AM
I have discovered the easiest way to find something is to stop looking for it. Or as you mentioned, buy a replacement.
Old May 19, 2021 | 07:36 AM
Sugar Bear's Avatar
How bout' the one that helps you look for that missing widget and asks..............
"Where is the last place you had it..." Sometime that is followed by a look 🙄 or " If I knew that...."
Old May 19, 2021 | 09:26 PM
smparr's Avatar
You guys were right, as soon as I shipped the defective one back the old one started howling when cold again. Still no GEN light though.
Old May 20, 2021 | 05:15 AM
Oldsdruid
Think Andy Griffith when the freezer broke: "Aunt Bee, just call the man!" and have that unit properly rebuilt.
Old May 25, 2021 | 10:13 PM
smparr's Avatar
I received the warranty replacement but the old one is still working, I'll get around to it sooner or later. Now my 1991 CC is having rotor warping issues. I swear these cars are jealous women!
Old Sep 3, 2021 | 04:22 PM
smparr's Avatar
Warranty replacement works great, the first replacement was defective.
nancydeen77
Apr 4, 2025 02:24 PM
JJSCUTLASS
Jun 11, 2013 07:22 AM
68conv455
Jul 12, 2011 06:59 PM
REDROCKER-S
Oct 5, 2009 05:20 PM
Gaz Hog
May 11, 2008 02:47 PM
