Couple questions switching to 100 amp internally regulated alternator
Old Mar 1, 2021 | 01:25 PM
724drcutlass's Avatar
So I have this 100 amp alt I want to install but first issue is do I have to upgrade wires and which ones? I currently have a 3 wire alt like the one in photo. Second is what do I do with external regulator? Just unplug it? I don't want to lose my gen dummy light in dash. Thanks, 72 cutlass.
Old Mar 1, 2021 | 01:45 PM
The wire you need to upgrade is the one that runs from the threaded BATT terminal on the alternator to the stud on the horn relay. If your original wire has a fusible link in it, you should use a maxi fuse that matches the amperage capability of the new wire.
Old Mar 1, 2021 | 02:33 PM
ok thanks, I believe it needs to be a 10 gauge wire. I'll double check. i see the diagram, do I need to reroute the ext regulator wires? Can I just leave it connected or will that confuse the charging system? I mainly just don't want to lose my charging idiot light, don't have a volt meter in car. Thanks
Old Mar 1, 2021 | 02:43 PM
The whole point of that diagram is to show you that you disconnect the harness from the external regulator and put jumpers in the connector to bypass it. You can by a pre-made jumper connector for this also, but frankly it's just four spade terminals and two pieces of wire.
Old Mar 1, 2021 | 02:47 PM
Gotcha, thank you
Oldzman71
Sep 2, 2018 03:36 PM
Tiha
Jan 21, 2018 06:49 PM
SeanMiller063
Aug 16, 2016 09:04 PM
WendellB
Apr 20, 2015 11:08 AM
jo75olds
May 29, 2011 01:03 AM
