100 amp alternator
Old April 19th, 2015, 07:55 PM
WendellB's Avatar
100 amp alternator
Replaced alternator Friday with a 100 amp one then was going for a drive when the ignition electrical shorted out causing a fire. My old alternator was an 80 amp one could the higher amp alternator caused my problem?
WendellB is offline
Old April 19th, 2015, 08:29 PM
No. It was something else.
MDchanic is offline
Old April 19th, 2015, 09:07 PM
WendellB's Avatar
Thanks!
WendellB is offline
Old April 20th, 2015, 07:20 AM
Did you replace it with a one-wire alternator? There are no factory 12SI alternators that are "100A", the largest was 94A.
joe_padavano is offline
Old April 20th, 2015, 11:06 AM
WendellB's Avatar
No the alternator used the same plug as the 80 amp one. If it was faulty could it have caused the short that fried everything?
WendellB is offline
Old April 20th, 2015, 11:08 AM
If it was faulty, yes, it could have.
Just the difference in nominal current output would not have caused it, though.
MDchanic is offline
442mark
September 30th, 2017 01:06 PM
HonestDave
January 19th, 2013 01:27 PM
yeahbuddy
March 6th, 2012 04:22 AM
68conv455
July 12th, 2011 06:59 PM
superstingray77
June 27th, 2011 06:13 AM
Quick Reply: 100 amp alternator
