advise for HEI and alt upgrade on 67 CS
Old Jan 27, 2021 | 12:38 PM
Papa D's Avatar
old67
Upgrading to HEI and 2 wire alternator during restoration, and looking for advise!
1. HEI. Should I tape off wires from coil and remove yellow/black from starter term "R"... and run new wire from IGN to HEI?
2. Alt ..Connect B+ to term # 2.... and remove plug from regulator, and then connect blue (from alt term #1) to brown (goes to warning lamp).?
Thanks for advise...
Old Jan 27, 2021 | 05:01 PM
Since I’m picky about my wiring, I prefer to remove everything that’s not used, and replace it with the new needed wiring.
Napa has the proper series 56 male terminals. Pull apart the electrical bulkhead connector, remove the old resistance wire, replace with a 14 gauge wire where the old resistance wire was. Same thing with the alternator wiring.
Old Jan 27, 2021 | 05:02 PM
Crap, I just noticed your car is a 67. I don’t think those cars used the series 56 terminals. Definitely make sure before cutting anything
Old Jan 27, 2021 | 09:25 PM
For the HEI on my car, I did exactly as you said in #1.
rodan
Jul 19, 2020 08:24 PM
Jonesmen
Sep 23, 2016 05:38 AM
Jannebill
May 14, 2013 09:01 PM
1973olds98
May 25, 2010 05:44 AM
Oldsproject
Jul 3, 2007 09:53 AM
