Points to HEI
Points to HEI
Hi everyone, doing a conversion from points to HEI on my 69 350 cutlass,what is the proper way of wiring it up?
Do you use the original power wire or do you have to run a new wire for more power?
I just cap the resistance wire from the bulkhead connector and run a 12ga wire from the IGN terminal on the fuse block to the BATT terminal on the Hei. You need to set your timing to 16* BTDC as the original timing setting is N/A for the Hei. Then you need to limit the vacuum advance to 10* and connect it to manifold vacuum.
