engine compartment relay
Old Jun 21, 2021 | 05:43 AM
JVCCutlass's Avatar
Hi all: I am trying to identify a relay (?) which is located under the hood on the drivers side. I have a 1971 cutlass supreme convertible.
it is halfway between the batter and the firewall and is bolted to the upper fender, has a number of wires going to it.
I think it has something to do with ignition but I am not sure.
Any help would be appreciated.
Joe JVCCUTLASS
Old Jun 21, 2021 | 06:27 AM
Joe JVCCUTLASS
Without a picture we're just guessing.
Old Jun 21, 2021 | 06:29 AM
briane's Avatar
I believe your referring to the horn relay.
Old Jun 21, 2021 | 07:25 AM
Or a high speed blower relay. Or an aftermarket relay.
Old Jun 21, 2021 | 09:15 AM
JVCCutlass's Avatar
Engine compartment relay ??
I saw this same question below -- did anyone give and answer ? What relay is this ??
Old Jun 21, 2021 | 09:26 AM
rocketraider's Avatar
Oldsdruid
If that's the one on your car that you're asking about, it's the horn relay and main power junction block.
A lead runs from battery (+) terminal to the junction block post and is the main power feed to the car. If you don't have the 1971 factory Olds Chassis Service Manual get one as well as 1971 Fisher Body Manual. CSM has color wiring diagrams and details how the wires go on the j/b post. The FBM has convertible top service info. Money well spent.
Should probably add that, in that picture, there's a whole lot of added wiring. Don't use it as a model for how yours should look. Looks scary to me, but my wiring repair standards are higher than most peoples'.
Old Jun 21, 2021 | 09:30 AM
briane's Avatar
That is the horn relay. The terminal with all the wires going to it, having that black plastic disk cover, is also a power distribution block. It receives power from the battery via a fusible link wire. That's the wire with a splice inside that molded cylinder, evident in the photo.
Old Jun 22, 2021 | 08:53 AM
JVCCutlass's Avatar
Thanks for the help - gotta get a new one, ebay is about $70 - ugh
Joe
Old Jun 22, 2021 | 08:57 AM
Will22's Avatar
Joe
I paid about $50 for a new one on Rock Auto for my 72.
Old Jun 22, 2021 | 09:29 AM
Oldsdruid
If you can find an American-made NOS or NORS part, go that way. GM Delco-Remy, Standard Motor Parts, NAPA Echlin, Niehoff, Filko are all good parts and likely to work and last better than new production from anywhere.
Old Jun 22, 2021 | 10:35 AM
Delco parts are not US-made any longer. Most of the others you mentioned are also imported now. Craig at Mobileparts may have NORS versions.
Old Jun 22, 2021 | 12:04 PM
As has already been mentioned regarding the purchase of a CSM manual (at a minimum), which will contain a colored wiring diagram, here are several images of my 1971 CS convertible (Power) Distribution Junction Block & Horn Relay. You need to identify all those wires in your labyrinth (crow's nest wiring), trace them, identify them & remove obsolete wires (they're a fire hazard and electrical nuisance).
srholt45@gmail.com
Nov 19, 2015 09:34 PM
Delta88Royale
Mar 28, 2014 07:25 PM
normadesmond
Sep 19, 2013 06:46 AM
jugdish
Aug 18, 2011 09:57 AM
rsandhoff
Jul 8, 2009 05:23 AM
