70 olds 442 loosing 12v to ignition intermittently
Old Dec 25, 2020 | 01:25 PM
COBRA2000's Avatar
Hi guy's Just installed my new Holley Sniper and Hyper spark system on my 1970 olds 442-w30 conv....Some how im loosing my 12-volt to the ignition system intermittently causing my car to cut off and back fire when it comes back on.. The pink wire from Holley is connected to the fuse bus to where i get a 12v reading in starting and run position...It typically does this on a hard acceleration....So i went ahead and hooked up the pink wire directly to the battery the system worked GREAT..... It also did this same problem with my regular points system....Suspect bas ignition switch....NEED HELP TO TROUBLE SHOOT PLEASE!!!
Old Dec 25, 2020 | 02:39 PM
Do the headlights go out also?
Old Dec 25, 2020 | 05:34 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Electronic ignition systems are sensitive to grounds. Check em, clean em, tighten em.
Old Dec 25, 2020 | 07:22 PM
Its probably not a ground issue as the car runs fine connected directly to the battery.
Old Dec 25, 2020 | 08:48 PM
COBRA2000's Avatar
No sir
Old Dec 25, 2020 | 09:38 PM
When this happens does the radio or anything else lose power also?
Old Dec 25, 2020 | 09:45 PM
COBRA2000's Avatar
No....I think it's loosing power between the ignition switch and the fuse box....
Old Dec 26, 2020 | 05:09 AM
My442's Avatar
The ignition switch is adjustable.
Check the CSM for instructions.
Old Dec 26, 2020 | 05:21 AM
COBRA2000's Avatar
What is CSM??
Old Dec 26, 2020 | 05:26 AM
dc2x4drvr's Avatar
Check the coil connection, and plug wires, etc...and go here and post the config file.and get sniper help.
https://forums.holley.com/forum.php
Old Dec 26, 2020 | 07:02 AM
My442's Avatar
I meant FSM - Factory Service Manual.
Sorry.
Old Dec 27, 2020 | 05:53 AM
COBRA2000's Avatar
Sorry.
Got it...
Old Dec 27, 2020 | 06:11 AM
COBRA2000's Avatar
Found the problem. Break down is in the bus at the fire wall..So we ran the wire directly to the ignition switch and all is good now..Otherwise we would have had to take out the brake booster and stuff,so my mechanic opted to do this procedure...PS: This Sniper system is something else...This system runs so smooth and so responsive. I think i gained a little horse power too...I"ll comment on it later in a separate post..
Old Dec 27, 2020 | 07:37 AM
Glad you found the problem.
Ronnie1972cutlass s
Apr 29, 2018 01:10 AM
rvandeven
Nov 11, 2014 05:27 PM
antweave
Mar 11, 2014 04:56 PM
J-(Chicago)
Jul 30, 2009 08:24 AM
daniel
Mar 11, 2009 01:33 PM
