View Full Version : Electrical
- Will not start
- Anyone know of a company that refurbishes fuse blocks?
- Ignition Switch or Distributor Wires
- 62 Starfire Fried Wiring
- N 34 pic for Hamm36
- Tail Lights
- Electrical Junction on Drivers Fender
- 72 Cutlass GEN Warning Light
- HID Headlights
- 69 Dash electrical gremlins
- Alternator Upgrade - 3800 V6
- 67 Cutlass Directional Connection
- Power Seat Wiring Diagram?
- No power to the starter "Please Help"
- No spark from coil?
- Windshield Washers on "Blue Belle"
- Underhood Light and Trunk Light Dead
- 1967 Cutlass supreme fuel gauge
- Instrument lights stuck on
- American Autowire Customer Service
- 70 Cutlass cigarette lighter
- Blower motor SQUEAL!- 68 442
- Regulator wiring
- voltage regulator smoking! help
- rpm gauge help
- deleting my ac what to do with the wiring?
- Charging system/Voltage regulator ground.
- timing marks
- Dashboard lights Question
- antenna problem
- tailights/backup lights......
- Alternator Placement.
- American Autowire dash harness
- 72 no crank issue
- battery drain
- 65 Cutlass Wiring Help
- 87 Olds Cutlass Key stuck in on position wont start nor can take the key out
- 65 Cutlass Voltage Regulator
- Strange Cluster issue
- Volt Meter causing an electrical drain (short?)
- info pls 70 window motor interchange?
- Turn signal switch
- Installed a Pertronix III Today
- Thick Purple wire (70 Cutlass)
- tach needle
- Need HORN for '51 Olds - 6 volt
- Power to Brake light switch.
- Wiper Switch Problem
- Chineseium amp gauge
- Neutral Safety Switch
- help with 70 442 wiring
- Any ideas?
- Fuel Guage/Sending Unit
- 70 Cutlass 350
- Proform 66438 install (1970)
- No Electrical Power
- Seat Belt Warning System for 72
- Cigarette ligther
- my wipers just stopped working
- 72 Cutlass gas gauge.
- 73 442 gas/oil gauge in 73 Supreme
- 72 wiring harness
- Lamp/Light Source Wire
- 1961 Olds 88 Clock Repair
- SW Tach installation questions
- 8 Volt system w Radio
- Power to Trunk Lid ??
- Delco Remy regulator
- GEN light and other electrical issues
- Doh! Starter cranks with ignition switch in "on" position
- Small Electrical Problem /66 Cutlass
- information for radio mounting
- Aftermarket Tach options that can replace Clock??
- 1964 Cutlass Wiper Pump Location?
- LED tail/turn/brake retrofit ?
- Speedometer Cluster Collector - 1968 Olds Cutlass S
- Autometer Gauges Wiring Help
- More electrical issues in my Cutlass!!
- help relay fuse ?????????
- Cutlass Mystery Wire
- Distributor Cap
- open face alternators?
- antenna question
- 4 Wire Alternator Replacement
- Ac blower relay
- keyless wireless remote
- 70 Cutlass Battery cable
- Anyone know Hot Rod Wires?
- Alternator help needed - 70 442 W-30
- Finding 12 volts to run HEI in a 64
- Can't find turn signal flasher, 1971 Cutlass S
- Help! My '65 Cutlass is Smoking
- buzzer/fasten seat belts light questions
- Help!! 72 cutlass supreme wont start
- Petronix Question
- Headlight switch
- Turn signals not flashing, 71 Cutlass S
- convertible motor troubleshooting
- no start condition
- In dash light issue--1970 Cutlass Supreme
- 49 radio needs a replacement
- For those of you with the Petronix
- 62 Starfire Convertible Pump/Motor Issues
- No , left signal , hazards
- Starfire electrical questions
- Has anyone ever seen one of these?
- 1972 Cutlass Fan Motor
- no start, no reason
- fuel sending unit
- 72 Olds Cutlass Supreme, possible eletrical problems
- 1970 Cutlass Clock--Please Help
- Tic Toc Tach
- Connect tachometer for Oldsmobile Dynamic 88 1966
- got a wire diagram for 66 67 Cutlass?
- Generator To Alternator Swap Question!!!
- 194 LED bulbs in 442 Guages
- Radio is ruining look of dash
- Unknown wires above transmission
- Looking for glass fuses
- Wonderbar radio
- 84 toronado dash cluster
- Who makes the best repo harness?
- ID Generator?
- What does this red cable control?
- Aftermarket gauges
- chewed wire help
- 1970 Cutlass Rally pack tach wiring
- Harness Question
- Heated Rear window 1972
- DUI Distributor
- 1984 98 Regency Brougham (Headlight Problem)
- 70 Cutlass radio wire diagram
- Car is paranoid,the horn goes off with the key in!
- Wiring Diagrams
- trunk release button
- power seatback release option diagram help
- 72 Toro: Sunpro gauge lights and trunk light.
- Power windows
- '68 Olds Cutlass S Electrical issue
- 1963 Olds ninety-eight Dash Lights
- Cleaning up messes
- Parts list 1972 Toro
- 6v to 12v conversion info please.
- Extreme Budget Stereo Install
- Wiring harnesses 1966 442
- Restoring metal power window / lock switches
- 2001 olds aurora
- power roof/antenna dash rocker switch, 68 delmont
- 72 Toronado Door Lock Solenoid / Actuator
- headlight switch control knob
- Cutlas Ciera 1994 - Radiator fan relay ?
- 1970 442 instrument cluster connector
- 70 cutlass Power trunk
- My rear lights stay on whats going on?70 cutty
- 70-72 wiper switch available
- headlight problem
- antenna
- 1972 Toronado - brake lights and many things
- Rusty fuse box in 68 Cutlass Supreme
- Alternator sparking w/ external regulator
- Wiring harness 1966 442
- battery draining
- I Need the Masters!
- Dash grounding question???? Stumped!!
- "66 442 guage light bulbs
- 1968 Cutlass insterment panel
- "hidden stereo" recommendations ?
- Universal Wiring Harness ???!?!
- Factory 8 track problems
- Aftermarket Rally Gauges
- voltage regulator
- Removal of dash gauges - 68 442?
- ignition switch parts exchange??
- I Need Help!!!!!!!
- Gauges, gauges who's got the best gauges
- 62 Starfire Wiring Problem
- Brightening the repro Rally Pac (and other RP stuff!)
- 71 455 Supreme Battery Cable
- Blower motor doesn't work on HI
- part needed
- R@R Turn signal sockets
- Windshield Washer Motor
- Power door locks
- Tachometer finish
- ECM ECU GURU
- Slight Hesitation in Starter - Follow Up
- 6 cyl to 8 cyl tic-toc-tach
- Super annoying chime module...
- Slight Hesitation in Starting - Ideas?
- Need some help identifying this electrical part
- 72 Supreme Signal, lights not working
- dash lighting grounds??
- Replica Batteries of the 50's
- Relocating a battery to the trunk, good or bad?
- My horn won't stop beeping!
- Positive Earth Radio Conversion
- 1972 Cutlass stopped dead in its tracks
- Winter indoor work-radio bench test
- Turn Signal Question - Electrical?
- dash light dilema
- 1972 442 battery question
- Any ideas?
- Fuel guage wire colors
- 1972 cutlass battery not charging
- Any experience with this vendor?
- Still low Voltage
- Disconnecting wires from washer pump
- turn signal switch replacement help
- in-dash clock
- 68 wiper switch wiring help
- Head lamps for '64 Ninety Eight
- 1978 98 regency diesel electrical problems
- Electrical system failure
- Blower motor resistor
- Reverb radio
- Working Under the Dash is a Royal Pain.
- coil, condenser wireing
- Help with Alternator part number (delco-remy):
- 71 Gas Gauge Question
- starter solenoid wiring
- 72 cutlass problem... stumped
- Wiring Harnesses-who makes them?
- amp light stays on when running
- Generator light on after Alternator swap
- help with 71 cutlass tail lights
- distributor application
- Reverse Lights not working
- difference between a 70-72 tic toc tach and 68-9
- Yellow/Blue wires connected to intake throttle solenoid...
- what do you think??
- oil/choke light stays on 90 custom cruiser
- where does the fuel sending unit wire route to?
- Electrical short in '75 Cutlass
- Horn relay 58-67
- LED tail light bulb replacements
- 65' Olds F-85 dash lights not working
- Accel Points Eliminator Question
- halogen light question
- Carb idle stop solenoid / electric choke
- starter sol with 3 connections vs. 2
- wire from battery to horn relay hot???
- converting alternator ext to int?
- No Spark
- taillight prob
- Fuel Gauge problem
- Pertronix
- help with starte
- HELP with starter circuit wiring
