help with starte
Old Sep 10, 2009 | 01:26 PM
kingkong8808's Avatar
help with starte
the motor is the 350 rocket and i have got three wires, i have got the wire running from the battery to the starter which is red, than i got red 12 gauge wire running from the starter to the firewall, and than i have a black 12 gauge running from the starter to i dont no where, and i cant remmber how to hook it back up
Old Sep 10, 2009 | 02:41 PM
bccan's Avatar
"Bypass" wire goes to coil. I'm embarassed to say I can't remember which side & don't want to tell you wrong, BUT, I think it goes to + side of coil. See if only one of the nuts is loose on the coil & that must/should be the one. It should be whichever lead DOESN'T go to the distributor. I'v been running HEI's in everything for so long I have forgotten simple details like that. The wire sends a full 12 volts to the coil for more available spark voltage while starting car, then when starter is disengaged coil is powered through lower voltage resistance wire from the ignition switch. As I recall, down at the starter the red heavier wire should be on the "S" (solenoid) terminal, bypass terminal is marked "R" (resistor bypass) iirc. Pathetic how when you have done something so many times you actually forget why or what the details were.
Hope this helps.
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
