View Full Version : Electrical
- Water temp sensor
- Upper Tail Light Plugs
- radio not working 1968 olds 98
- Right Brake Light Not Working - '65
- electrical help
- 70 fuel gauge repair
- 1956 Headlight switch
- 1950 Olds 88 electrical/starter problems
- 1958 olds 88 clock
- Tachometer
- Ever see the inside of your fuel sending unit?
- DVS switch?
- Petronix _ NEVER AGAIN
- Heelp horn relay wire, wich wire? cutlass 65
- 67 cutlass fuse box?
- 72 cutlass - Back up lights Inop
- Multi-Function Chime Module
- 1972 Cutlass Supreme horn question 🤔🤔🤔
- Hickory Dickory Dock...
- Always hot?
- 68 442' radio antenna in windshield.
- 68 cutlass turn signals not working
- ignition burning up
- Blinker
- Fasten Seat Belt Light is haunted!
- No power to ignition 1970 Cutlass
- 68 442 Starter questions
- 65-66 Big Car Switch Pitch Kickdown Switch Servicing
- Battery draw
- Instrument Cluster dark, interior lights work, charging battery light on.
- Brake light on in dash (yup, me too)
- High blower fuse location
- '82 307 Y Coolant Level Sensor
- 1966 Cutlass Radio 7289373
- 1970 cutlass w31 -350 rocket -GEN LIGHT
- Where to Buy Connectors/Plug
- Cruise Control
- Anyone know Wire where this goes to
- 1950 Olds 88 clicking sound when key in RUN
- Wipers not working
- 69 442 starter question
- A/C Compressor
- Thief Destroyed my Illuminated Door Lock. Need new ones
- 1961 Overcharging, with 2 new voltage regulators tried
- Rover ignition amplifier
- Wells VR715 voltage regulator mounting
- To Beep or Not To Beep
- 70 AM/FM radio mono?
- Need help with 1957 radio
- Distributor Cap Set Screw
- OEM style battery cables with a BBO and headers?
- Charging dead battery - killed voltage regulator, what causes this?
- 1973 Cutlass headlight switch extremely hot to the touch
- Lights in Dash
- Blower motor fuse
- Clock bulb replacement question...
- What does this wire go to?
- Interior lights, courtesy lights, and fan questions
- Turn Signal Flasher - LED Compatible
- Pertronix Distributor and Mini Starter Wiring Question
- Power Window Regulator Tape Years??? Interchangeable?
- Adding Auto-Dimming Mirror??
- Stuck at TJ Maxx, no start!
- Need new antenna 65 Cutlass
- 1961 88 turn signal/parking light wiring
- Dash Lights
- Fuel Sending Unit Issue
- Courtesy lights not coming on with headlight switch.
- She won’t start 😩
- Blower fan inop
- 71 442 Manual Trans Wire Diagram
- Nightime dashboard light show
- Ignition Accessory Option
- RF noise gremlin
- Air Conditioner Won't Shut Off
- Testing 8 Track
- 71 cutlass washer motor
- Help ID'ing Wire Harness
- Accessory power source
- Rally Gauge Instrument Cluster
- 88 1998 tail lights and cluster light off chimes on opening door
- Part number for 65 cutlass ignition switch
- Starter/Solenoid removal
- Best battery?
- 1973 Cutlass — A/C switch turns on every setting except A/C
- Power Window Motor hole template
- GEN light
- battery draining after week of non use -tic toc tach causing?
- Loud Signal Flasher Sought
- Night Watch
- A/C Blower Fuse Keeps Blowing
- cruise control
- 72 tail light socket replacement
- 70 442 Tail lights & dash lights not working
- Gauge lights suddenly not working 72 cutlass
- Starter and/or transmission issue
- 1964 Oldsmobile 98 wiper
- 64-65 Cutlass Battery Hold Down
- 66 442 heater/ac fan switch
- Turn signal canceling
- 73 Cutlass -- Blinkers only blink on left, no clicking on right.
- Anybody use aftermarket keyless power lock kits with key fob?
- Alternator rebuild
- Radio Fit for a 1968 Cutlass
- 58 88 4dr clock
- Points to HEI
- 1980 442 Radio Wiring
- Electric issue
- Coil Wire Part Number
- Fuel Gauge diagnosis
- No brake or tail lights
- No Power in interior or headlights but horn and convertible top work.. Need Help!
- NEED IGNITION RACK KIT for 71 cutlass Supreme
- Ignition fuse?
- Wire boot for sending unit
- Hood / Trunk Light Power Source?
- Blinkers on dash inop ?
- Fuel Gauge
- Bypass external regulator F-85 1963
- Gotta be ground right??
- Braking turns on turn signals
- Alternator F-85 3,5 1963
- Passenger Door Power Window
- No more turn signal, help needed
- wire colors
- Red or black?
- 1968 442 No Head lights, No Tail Lights No Charging
- D o o r b u z z e r!!!
- Distributor brand F-85 215cui ?
- 1971 Original GM Oldsmobile CSM Wiring Diagram A Body "V-8"
- Restore a '65-66 Big Olds Clock: Quartz conversion tip
- 1969 Cutlass Brake/Hazard Lights Mystery
- Fuel gauge not reading correctly
- 1969 442
- Reverse light help
- Deeper headlamp retaining rings?
- 1969, 442
- 67 C/S headlights
- 64 Starfire mystery wires
- 71 convert blue wire passemger side under carpet
- Dual alternators anyone???
- 68 442 console wiring
- 1952 ignition switch
- Left turn signal not working
- Bluetooth FM transmitter on 77 Oldsmobile
- Radios for a 71 98?
- 1961 88 Fuel Sender wiring routing
- Reproduction Tic Toc Tach
- Need help with electrical issue 2001 Olds Alero
- 1972 Convertible Interior Lights
- 69 Cutlass Elec Trunk Release
- Maxi fuse terminals?
- 72 AM/FM Radio Power/Speaker
- Thin black wire from the battery > the starter solenoid
- 72 cutlass supreme steering column rod
- 371 starter
- Trunk release electrical wiring - 69 Cutlass
- Help 72 cutlass over charging
- 66 Delta 88
- Regulator?
- 1970 442 Map Light
- New alternator is not charging
- Dim taillight
- 72 Olds Cutlass windshield washer pump wiring
- Defogger/AC relay wiring
- Replacing gauges wiring question
- Distributor Wiring
- A/C and Blower Wiring help - Please :-)
- Removing connector from its plug housing
- horn button assembly oldsmobile 1959 dynamic 88
- Dim Parking and turn signal light front drivers side
- Night Watch
- No tail lights or dash lights
- electrical-kickdown switch
- Anti-Theft Kill Switch
- Alternator; Proform or Tuff Stuff ?
- 68 442 trunk light.
- Blower speed switch?
- One step forward, 1/2 a step back
- Battery Cable Routing With Headers
- Oldsmobile Delta 88 Royale 1978
- 68 442 temp light
- 1966 Toronado Stop Lights
- Dome Light Contacts
- 1972 Cutlass Factory Rally Pac
- Ignition key buzzer/seat belt buzzer don't work..
- 72 Olds Cutlass randomly cuts out\dies
- Part needs identified
- 67 Rally Pac Help
- Coil/carb wiring help
- 68 rally pack clock
- Door buzzer
- Turn signal
- Unknown chime module?
- Courtesy Lights
- 70 442 ash tray light
- Alternator Questions
- Gen light help
- Horn Wiring 1971 A Body: Ground ?
- 70 Cutlass tail light issues
- Classic update- no ac harness?
- What relay for electric choke conversion?
- Voltage regulator
- LED Bulb Fitment
- Power Window Issue- one window
- Kickdown wire
- Alternator/Battery Issue
- Hello german Olds enthusiastic need some help
- Tail light fuse .
- MSD 8529 Timing
- Oldsmobile 1953 Holiday Coupé power window
- 1988 Oldsmobile regency brougham coach lights
- Bosch tach install 67 442
- New gauge ground wire (chassis)
- Need help wiring up 12V ignition switch board
- Wiring 68 am radio
- Alternator
- Help on HEI spark plug wires for 400 engine
- Brake light switch
- Power windows
- Tips on '51 dash removal?
- 64 cutlass convertible - bad ground?
- Wires near blower motor.
- 67 C/S rear bumper install wiring
- power door locks
- Gauges?
- Wiring
- Distributor Rebuilder
- Battery Drainage Issues
- Distributor help!
- Possible voltage regulator issue
- Wiring update main fuse location?
- Courtesy Lamp lens removal 1970 98
- Help with headlight replacement
- 1972 Cutlass reverse switch 4 speed
- 72 rally pack tach reads high
- New Generator Smoking + Voltage Regulator Question
- Wiring harness for 66 442
- Fuel gauge problem
- Positive battery cable length?
- Best Radio for a 75 D88?
- 3rd gauge options
- Trouble shooting a washer pump.
- 66 Cutlass headlights
- 72 Cutlass Reverse lights
- Starter solenoid fitment
- Stop lights
- Wiper switch only works when I push it in
