Battery Drainage Issues
Old Mar 27, 2020 | 09:44 AM
Marcus Strange Sr.'s Avatar
Hi guys...I have a 87 cutlass supreme with a swapped 350 rocket... I'm not sure what to ask but when I connect my negative battery terminal my car begins to squeak, and seems to lose power as well..I have and optimum red top battery and I upgraded the "big 3" on the alternator and still no luck. Any suggestions guys? Thanks
Old Mar 27, 2020 | 10:02 AM
I'm not sure what answer... Are you connecting the Optima battery with the car running, Where is the squeak coming from, what is the big 3 that you upgraded?
Old Mar 27, 2020 | 10:08 AM
Also, what do you mean by "losing power"? Is the engine output reduced, or is the voltage decreasing?
Old Mar 27, 2020 | 10:17 AM
If there's a parasitic current draw on the battery remove fuses one at a time until the current draw goes away.
ELECMAN
Mar 18, 2020 02:17 PM
Neil Morrison
Feb 28, 2020 06:35 PM
kingjames788
Dec 8, 2014 10:15 AM
76olds
Mar 3, 2014 03:31 AM
FATRATMATT
Jul 9, 2010 08:18 AM
