Tail light fuse .
Tail light fuse .
The tail light fuse blows after about ten minutes . I’ve UN plugged the tail lights. At the rear trunk plug . Trying to get to headlight switch to replace it . Any way to trouble shoot this in steps ? Or has anyone ever had this problem? Can’t figure out why it takes so long for it to blow . If I leave the instrument lights off won’t blow . Checked every wire plug and bulb
So you need to read minds to figure out I’m having a taillight issue ?I didn’t state the year or make by mistake I was in the forum for olds cutlass electrical issues .I’m not familiar with using the tools on this forum obviously .I am truly sorry if I caused you some kind of harm or distress in anyway . I just thought I might get some constructive help from fellow olds owners .I have searched every post I can find on the issue .
Including these two? My money is on the pigtail for the under hood light.
https://classicoldsmobile.com/forums...cutlass-60583/
https://classicoldsmobile.com/forums...ng-fuse-84059/
Taillights
