Tail light fuse .
Old Apr 20, 2020 | 09:11 AM
Ozzy's Avatar
Tail light fuse .
The tail light fuse blows after about ten minutes . I’ve UN plugged the tail lights. At the rear trunk plug . Trying to get to headlight switch to replace it . Any way to trouble shoot this in steps ? Or has anyone ever had this problem? Can’t figure out why it takes so long for it to blow . If I leave the instrument lights off won’t blow . Checked every wire plug and bulb
Old Apr 20, 2020 | 09:46 AM
I'm not certain what the actual issue is you're having, but the majority of us remain incapable of mind reading. I'm assuming your issue pertains to a 1957 Oldsmobile Super 88 Holiday Coupe?
Old Apr 20, 2020 | 10:04 AM
Ozzy's Avatar
71 olds cutlass when the headlights are on and the gauge lights are turned on the tail light fuse blows slowly takes ten minutes or so .
Old Apr 20, 2020 | 10:15 AM
Ozzy's Avatar
So you need to read minds to figure out I’m having a taillight issue ?I didn’t state the year or make by mistake I was in the forum for olds cutlass electrical issues .I’m not familiar with using the tools on this forum obviously .I am truly sorry if I caused you some kind of harm or distress in anyway . I just thought I might get some constructive help from fellow olds owners .I have searched every post I can find on the issue .
Old Apr 20, 2020 | 11:56 AM
Including these two? My money is on the pigtail for the under hood light.
https://classicoldsmobile.com/forums...cutlass-60583/
https://classicoldsmobile.com/forums...ng-fuse-84059/
Old Apr 20, 2020 | 04:44 PM
Ozzy's Avatar
Taillights
It was the headlight switch! One end of the coil for the instrument lights was burned in two . Strangely everything worked . Just blew the fuse after ten minutes . I found the pig tail under the hood it was taped up . Thank you !
Old Apr 20, 2020 | 05:11 PM
PatL's Avatar
The under hood light only works when the headlight switch is on; if you were curious on what the connection between the two are.
Old Apr 20, 2020 | 05:34 PM
Ozzy's Avatar
Underwood light
Yes I know I got a schematic today and studied it all . I’m getting a 12 volt light with a retractable cord to put under the hood .
Rocket North
Sep 6, 2017 06:51 AM
Ronschwartzsr
Jun 14, 2017 04:21 PM
Colpage1
Jun 22, 2015 08:19 PM
AAM
Jun 6, 2012 11:08 AM
Lilly
Oct 24, 2006 05:06 AM
