D o o r b u z z e r!!!
Old Jun 23, 2020 | 09:57 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
OK I know something about electrical but not a lot the door buzzer needs to be unhooked it’s a nightmare every time I open the drivers door the neighbors can hear it down the block it’s so loud.
I also noticed that the horn relay is where the buzzer is coming from is it two into one and can you deactivate the door buzzer without losing the light switch in the jam if you know what I mean
Old Jun 23, 2020 | 10:12 AM
Unplug the green wire from the horn relay and the door buzzer will be disconnected and everything else will still work. I found that on my car back in 1980 and it's been unplugged ever since then.
Old Jun 23, 2020 | 10:46 AM
Olds Specialist LOL
Cool, I New it was probably simple thanks!
That is a big help annoying every time I work on the driver side
QUOTE=Fun71;1259189]Unplug the green wire from the horn relay and the door buzzer will be disconnected and everything else will still work. I found that on my car back in 1980 and it's been unplugged ever since then.[/QUOTE]
Old Jun 23, 2020 | 12:06 PM
JohnnyBs68S's Avatar
^^THIS. My dad disconnected that back in '74 just after he acquired my car from his neighbor.
Old Jun 23, 2020 | 12:33 PM
Olds Specialist LOL
My Wire was red on mine the other two wires didn’t shut the buzz off but the red wire did.
seems like everything else still works.
Old Jun 23, 2020 | 02:12 PM
Sorry for the incorrect wire color - was going from memory and got it wrong. You are correct the red / black stripe wire is for the key buzzer. The green wire goes to the horns. The third wire goes to the steering wheel horn switch.
Old Jun 23, 2020 | 02:18 PM
I thought it was a pink/black stripe wire for the door buzzer. The green and black are for the horns.
Old Jun 23, 2020 | 02:23 PM
Pink and Red are the same color to me, especially when looking at 50 year old faded wires.
Old Jun 23, 2020 | 02:51 PM
Olds Specialist LOL
I just pulled wires off until buzz sound went out and it was on the last wire pink maybe looked quick thought it was red maybe faded.
thanks again
next is how to adjust kick down on my turbo 350 trans.
it kicks down too much while cruising 45-50 hits 1st gear I want it to hit 2nd not 1st
well it hits 2nd but if I step on it too much it goes to 1st you know what I mean.
no cable is it electric? Vacuum?
QUOTE=Fun71;1259268]Sorry for the incorrect wire color - was going from memory and got it wrong. You are correct the red / black stripe wire is for the key buzzer. The green wire goes to the horns. The third wire goes to the steering wheel horn switch.[/QUOTE]
Old Jun 23, 2020 | 03:09 PM
Your T350 kick down is cable operated. It should be engaged close to wot. It should not shift down to 1st at 45-50mph.
Old Jun 23, 2020 | 03:12 PM
Olds Specialist LOL
I didn’t see a cable, is it located on the driver side of the carb? Or is it at the gas pedal?
Old Jun 23, 2020 | 03:21 PM
Gas pedal
Old Jun 23, 2020 | 03:44 PM
The kickdown cable forces a downshift based on engine RPM and vehicle speed (MPH). The speed (MPH) that it kicks down will depend upon the rear gear ratio so it will be different with different rear gears. My car with a 2.56 rear gear would downshift to 1st at 50 MPH then upshift at almost 60 MPH (4800 RPM). Now with 3.23 rear gears the downshift and upshift RPM is the same but the vehicle speed (MPH) is lower.
So depending upon what rear gears your car has (standard no-cost equipment is 2.56:1), the downshift to 1st at 45-50 MPH may be correct operation.
Old Jun 24, 2020 | 01:49 PM
green1972's Avatar
the kickdown goes from the gas pedal directly into the transmission by the transmission dipstick tube, Tim
Old Jun 24, 2020 | 02:08 PM
Olds Specialist LOL
So that’s what the extra cable is on the gas pedal, oh I see you adjust that little clamp thing on it simple.
thanks!!!
[img]https://cimg0.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/73725833_d6bb_465c_a662_8e25d4064ee2_28e461c243f79 841fdabe253b8f6da867397eed9.jpeg
Extra cable on left side?
oh
QUOTE=green1972;1259563]the kickdown goes from the gas pedal directly into the transmission by the transmission dipstick tube, Tim[/QUOTE]
asscutl
May 6, 2020 04:26 AM
rand5204
Nov 1, 2019 05:34 AM
rml442
Jun 5, 2015 10:59 AM
NINETY_EIGHT_REGENCY
May 18, 2014 07:12 PM
shot12
Oct 11, 2009 01:53 PM
