Horn Relay Buzzes
Old Oct 29, 2019 | 02:18 PM
rand5204's Avatar
Horn Relay Buzzes
Key in, key out,, door open, door closed. Every time I connect power, regardless of where anything is set at. the key buzzer sounds until I disconnect the power again Electrical issues truly are my weak point. How do I make the madness (or buzzer) stop. Thanks for your help. The car is a 70 442 convertible.
Old Oct 29, 2019 | 02:39 PM
Disconnect terminal #4 at the relay.
Old Oct 31, 2019 | 04:51 AM
rand5204's Avatar
Eric,
Thanks but is the terminal marked? Which one is #4?
Old Oct 31, 2019 | 11:40 AM
ecwieder's Avatar
Eric
Should be the one with the pink/black wire on it. If you pull it and it still buzzes it's a fail inside the relay.
Old Nov 1, 2019 | 05:34 AM
rand5204's Avatar
Thanks. I will give this a try. If it fails to stop the buzz then it's the second brand new $75 relay that was bad. Actually it would be the third. ON my blue car the horns blew continuously while power was connected. Replacing the relay solved the problem immediately. Pretty irritating to have to replace brand new parts.
cwebb1020
Nov 13, 2017 06:50 AM
slam1918
Nov 19, 2013 07:33 PM
jugdish
Aug 18, 2011 09:57 AM
Kidcutty
Feb 11, 2010 06:52 PM
shot12
Oct 11, 2009 01:53 PM
