Regulator?
Old May 24, 2020 | 04:39 PM
Jhucks03's Avatar
Regulator?
Battery was dead the other day. Charged it up. Low charging voltage while running. And goes dead while sitting for a while.
Not real familiar with externally regulated alternators.
Old May 24, 2020 | 05:22 PM
If you have a question it may help to say what you are working on so folks can give accurate information for your vehicle.
Old May 24, 2020 | 05:27 PM
Jhucks03's Avatar
71 Cutlass with 455
HEI ignition
No radio/ac/power windows or locks
Full field on regulator only nets 12.6 Volts
Old May 24, 2020 | 07:55 PM
Is the charge light on? If you charge the battery to 12.6 and let it sit not connected to anything, will it hold the charge? I've seen shorted batteries that can put a load on the system and you won't see the full charging voltage.
Old May 24, 2020 | 08:54 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Basic troubleshooting...start simple....Check all Grounds and other connections. Clean and inspect both ends of both battery cables. Load test the battery.
Verify what alternator you have before we go any farther. Note the numbers on it and snap a pic or two showing the rear and/or side connections
Old May 25, 2020 | 12:16 AM
Killian_Mörder's Avatar
If the battery's over 8 years old, there's no sense in going further with diagnosis, until it's replaced
Old May 25, 2020 | 06:34 AM
Jhucks03's Avatar
Battery about 6 months old. But I did charge it unhooked last night and I’ll check it this morning, as I was leaning towards it giving problems. Will update.
Old May 25, 2020 | 08:37 AM
Sometimes newer batteries fail, depending from where they're imported
Old May 25, 2020 | 08:59 AM
Jhucks03's Avatar
Battery held. 1.7amp draw with everything hooked up. 0 amp with either alternator or regulator unhooked.
Alternator got slightly warm while battery charger was hooked up. Found that odd, but not sure. Never paid attention to any other vehicles before.
Old May 25, 2020 | 09:08 AM
Sugar Bear's Avatar
With the engine off and all accessories off there shouldn't be nearly that high of a current draw. If unplugging the alternator stops the draw then it sounds like there is a bad diode or a leakage in the alternator.
Good luck!!!
Old May 25, 2020 | 09:13 AM
Jhucks03's Avatar
Thanks! I’ll entertain swapping to an internally regulated unit at the same time.
crazzmc
Mar 21, 2020 04:59 PM
niko000
Aug 11, 2017 12:48 PM
Mike70GoldOlds
Apr 23, 2015 12:58 PM
dom992
Aug 7, 2014 11:26 AM
71 Cutlass
Aug 22, 2010 11:44 AM
