Blower fan inop
Old Aug 23, 2020 | 03:30 PM
wherlehy's Avatar
Blower fan inop
1970 Cutlass - 350 Rocket
My A/C fan just stopped working - all fan speeds. I believe because all speeds do not work it is a blown fuse. Where is the blower fuse and relay located?
THanks,
Bill
Old Aug 23, 2020 | 04:04 PM
There is an inline fuse holder with a separate 30A fuse for the high speed fan only in the wire that runs along the firewall, and there is a fuse in the fuse block for the low speed fan settings. If you have no fan at all, either both fuses are blown or the problem is something other than the fuses.
Old Aug 23, 2020 | 04:13 PM
wherlehy's Avatar
Will check the 30A inline fuse. The low speed fuse in the fuse box is fine.
Bill
Old Aug 23, 2020 | 04:21 PM
wherlehy's Avatar
Just looked under the hood for the 30A inline fuse along the fire wall. Does anyone have a picture of what it looks like?
Old Aug 23, 2020 | 05:02 PM
wherlehy's Avatar
Is this it?
Old Aug 23, 2020 | 07:09 PM
I moved your posts to its own thread instead of hijacking one that has nothing to do with your issue.
Old Aug 24, 2020 | 05:15 AM
Since the motor doesn’t work on any speed, the blower motor or high blower relay is a likely suspect. Do you have access to a wiring diagram?
Old Aug 24, 2020 | 06:18 AM
^^^THIS. The high speed power supply is completely separate from the low speed supply. The only common parts of the circuit are the motor, the wire from the high speed relay to the motor, the relay itself, the motor ground wire (on A/C cars only), the fan speed switch on the faceplate, the internal master switch, and the power to the control head (since this not only operates the low speeds directly but also operates the high speed relay).
The very first test is to see if the blower motor works. Pull the connector off the high speed relay and apply 12V to the purple wire in the connector. If the blower runs, the motor is good. If not, figure out why. Note that A/C cars have a separate ground wire from the motor to the firewall due to the fiberglass HVAC box. Heater-only cars use a metal box and don't need this wire.
Old Aug 24, 2020 | 07:25 AM
wherlehy's Avatar
A wiring diagram would help - thank you.
Old Aug 24, 2020 | 07:27 AM
1970 Chassis Service Manual, page 1C-12, figure 1C-20.
Old Aug 24, 2020 | 02:57 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
[QUOTE=wherlehy;1273767]Is this it?
[/QUOTE
Test your hot wire at the blower that’s where I start. Most times it’s just a bad connection.
Old Aug 24, 2020 | 04:36 PM
wherlehy's Avatar
You guys are the best!! With your help and following the wiring schematic it ended up being a loose 50 year old connection.
Thank you all for your help!!
-Bill
Old Sep 29, 2020 | 11:46 AM
Olds Specialist LOL
-Bill
Thanks!
JOHNNYOLDS442
Mar 8, 2022 09:24 AM
COBRA2000
Dec 7, 2019 06:56 AM
mmurphy77
Jun 17, 2014 12:49 PM
sfh074
Sep 28, 2013 07:52 PM
Blaster
Oct 6, 2011 06:11 AM
