"Hi" Fan Speed out ...
The High Fan position on my 1978 Delta 350 is now dead, the other speeds are fine ..
I thought there was a seperate fuse or breaker for "Hi" , but looking in the owners manual I only see a listing for one 25A heater/AC blade fuse...
Anyone have any knowledge?
I don't know about '78, but for earlier years, the main schematic only shows the non-A/C system. You have to go to the A/C section for the right diagrams.
Probably the high-speed fuse or relay is bad.
Any ideas where I'd find it ?
high speed fuse...
I had a '78 Toro and if I remember right, there was a separate fuse for high speed on the fan motor. I think it was an inline fuse out under the hood, near the firewall--but that's been several years ago.
I've slept a few times since then...
Rockettruck...
Rockettruck...
Look inside the car passenger side under the dash. If it's the same type of setup as the 69 it would be on the top of the air box. I don't know if you can get to it without removing some stuff but you should be able to at least feel for it up there.
81 regency
Apr 21, 2011 06:18 PM
gearheads78
Dec 19, 2010 03:28 PM
