"Hi" Fan Speed out ...
Old Oct 2, 2011 | 04:29 PM
Blaster's Avatar
The High Fan position on my 1978 Delta 350 is now dead, the other speeds are fine ..
I thought there was a seperate fuse or breaker for "Hi" , but looking in the owners manual I only see a listing for one 25A heater/AC blade fuse...
Anyone have any knowledge?
Old Oct 4, 2011 | 05:30 AM
Willidog's Avatar
Official Tire Kicker
Do you have A/C? In my 69 there is a relay/resistor on the airbox under the dash that if it goes bad you lose the low and medium fan speeds.
Old Oct 4, 2011 | 06:15 AM
I don't know about '78, but for earlier years, the main schematic only shows the non-A/C system. You have to go to the A/C section for the right diagrams.
Probably the high-speed fuse or relay is bad.
Old Oct 4, 2011 | 10:10 AM
Blaster's Avatar
Yes, I have AC, & "thought" there was a high speed fuse or relay, but there's no mention in the owners manual of a Fuse or breaker for "high" ...
Any ideas where I'd find it ?
Old Oct 4, 2011 | 11:30 AM
rockettruck's Avatar
high speed fuse...
I had a '78 Toro and if I remember right, there was a separate fuse for high speed on the fan motor. I think it was an inline fuse out under the hood, near the firewall--but that's been several years ago.
I've slept a few times since then...
Rockettruck...
Old Oct 4, 2011 | 11:34 AM
On the older cars it's in the line between the big horn relay terminal and the high-fan relay, along the back of the engine.
Don't know about the newer cars, though.
Old Oct 6, 2011 | 06:11 AM
Willidog's Avatar
Look inside the car passenger side under the dash. If it's the same type of setup as the 69 it would be on the top of the air box. I don't know if you can get to it without removing some stuff but you should be able to at least feel for it up there.
convertible 63
May 9, 2018 06:10 AM
cdoering
Mar 9, 2015 03:38 AM
67442nut
Dec 7, 2014 06:40 PM
gearheads78
Dec 19, 2010 03:28 PM
